Old 01-25-2006, 01:49 PM   #1 (permalink)
Dressler's Avatar
REAR END Wobble/Shake
The rearend seams to starts to shake and wobble at about 45 mphs. I have had my tires ballanced 3 times and rotated.
has anyone else had this problem?
http://www.titantalk.com/forums/profile.php?do=editsignature#
http://www.titantalk.com/forums/profile.php?do=editsignature# green
Dressler is offline   Reply With Quote
Old 01-25-2006, 01:57 PM   #2 (permalink)
Sammy Sandbag's Avatar
Re: REAR END Wobble/Shake
Do you have aftermarket tires/wheels/lift/etc?
-Counsel Yourself
2009 Blizzard Pro-4X
Old 01-25-2006, 06:06 PM   #3 (permalink)
Titan Fever's Avatar
Send a message via Yahoo to Titan Fever
Hey Sammy is that a honeywell FLIR set up your sporting in your titan? Ha ha
You HATE the Titan, Compared to How Much I LOVE IT!
Titan Fever is offline   Reply With Quote
Old 01-25-2006, 07:57 PM   #4 (permalink)
Yeah, it's part of my stealth mode modification. Turn off the lights and just drive.
-Counsel Yourself
Old 01-26-2006, 12:21 PM   #5 (permalink)
A2titan's Avatar
I and others had posted about this some time ago. To lazy to look it up right now. Worked hard with my service manager to figure this out, did the same route, and also complained to the 800 number a number of times. What I found out in all this is it's due to engine lugging due to shift point of 5th and converter lockup being set so low in an effort to gain EPA mileage ratings. You can see this if you can get the lugging vibration around 45-46, then drop it into fourth. Vibration is Bye-Bye. A simple programing change would fix, but claimed EPA mileage would be affected and have to be changed on the window sticker and other press material.
05 Smoke SE CC Big Tow 4X4, Mods: PRG 2" front-PRG 1.5" rear,PRG rear Bilsteins, Banks Exhaust, Front Air Dam, Power Tailgate lock, Fram Air Hog, Prodigy brake controller, Extang Trifecta bed cover. Bed Fade TSB performed by Rhino!
A2titan is offline   Reply With Quote
Old 01-26-2006, 01:38 PM   #6 (permalink)
IQ9
AH yes, our friends at the lovely EPA. Keeping the red tape to a maximum.
Crew Cab,Pearl White,LE,Venture Clear Bra, Debadged, PML Dif Cover, 285/60/18 Nitto Terra Grapplers & Stillen BBK
IQ9 is offline   Reply With Quote
Old 02-06-2008, 06:29 AM   #7 (permalink)
A2titan, were you able to fix/resolve the rear end wobble/shake on your titan by reprograming the transmission?
mygunstoo is offline   Reply With Quote
Lots of Steering wheel shake jglennd Titan Problems & Dealer Service 12 11-28-2005 06:10 PM
Need a better shock for bed shake MuskyHunter Titan Parts & Accessories 2 11-27-2005 04:17 PM
shake/shudder (but not during braking) f00dstamps Titan Problems & Dealer Service 13 09-01-2005 05:08 PM
Titan Bed Shake BULLTITAN Titan Pictures & Media Post 2 06-14-2005 01:14 PM
drivers side mirror shake jhromy Titan General Discussion 18 03-27-2005 06:59 PM
