Old 02-25-2006, 06:29 PM   #1 (permalink)
In dash power outlets question, switched power?
In past vehicles I've owned there was a way to change the setting for switched power or constant power to the in dash outlets. Is there any way to do this on the Titan or am I stuck with constant power to the outlets? I have a Garmin 2720 plugged in and would like it to turn off with the truck as I keep forgetting and leaving it on and am worried I'm going to come out to a dead battery soon.
Thanks for any help.
LBTRS is offline   Reply With Quote
Old 02-25-2006, 06:32 PM   #2 (permalink)
Send a message via AIM to oktex88
Re: In dash power outlets question, switched power?
Left one stays on all the time, right one turns off.
2004 Nissan Titan - Cash Settlement with Nissan for Water Leak March 2008
oktex88 is offline   Reply With Quote
Old 02-25-2006, 06:34 PM   #3 (permalink)
Titano24's's Avatar
Send a message via AIM to Titano24's
^^^^i'm with him since hes right haha
2004 CC 4x2 Titan LE (White)
Engine : AEM Brute Force, Airraid TBS, TB Coolent bypass, Deleted Resenators, Banks Monster Exhaust
Looks : 22" Giovanna Aburzzo's, 20% Tint, Painted Armada Front Lip, Truxedo Lo-Pro Bed Cover, 2" Rear drop, In-channel Vent Visors, OEM bugshield
Entertainment : Kenwood DDX-7015, JL Audio 1000/1, JL Audio 450/4, JL XR 6.5 Components, 2 x JL Audio 8"w7's, Audiocontrol 6XS, Kinetik 2000 and 800 batteries, *coming soon Iraggi 220amp alternator*
Titano24's is offline   Reply With Quote
Old 02-25-2006, 06:44 PM   #4 (permalink)
If you want to hard wire it instead of having it plugged into the power socket, you can use a fuse tap or LittleFuse mini-blade add-a-circuit and tap at the fuse panel on the passenger side in the cab. Just tap something that goes on - off with ignition (the fuse panel cover is marked BAT & IGN I think) & don't exceed the total max fuse rating of the circuit.
Old 02-25-2006, 07:17 PM   #5 (permalink)
rcantu's Avatar
yep I agree. they know what they are talking about
pics of the Titan
Old 02-25-2006, 07:24 PM   #6 (permalink)
You guys are awesome...been using the wrong one.
Thanks,
Old 02-27-2006, 10:22 AM   #7 (permalink)
phlydude's Avatar
also if you have the center console, the rear outlet on the floor is switched...
With the GPS, Cell and XM Radio all my outlets inside the truck are spoken for!
I do Blu, do you?
phlydude is offline   Reply With Quote
Old 02-27-2006, 11:53 AM   #8 (permalink)
grunge311's Avatar
But the one in the bed is constant.
grunge311 is offline   Reply With Quote
Old 02-27-2006, 12:08 PM   #9 (permalink)
Why not just use the passenger's side power outlet. On many, if not all Titans, the passenger's side is switched, the driver's side isn't?
But if I am wrong, keep reading.
How many wires are going to the power outlet itself?
I would simply use a stanard SPST 30-amp Automotive Relay. Quick, simple, best way to do it, without "tapping" into the fuse block. Cut the main 12v wire powering your outlet. Pin 85 on the relay goes to ground, Pin 86 goes to your switched power source (anything with ignition only), Pin 87 goes to the harness side of the wire you cut, and Pin 30 goes to the power outlet side of the wire you cut.
When your truck is off, the relay is off (not activated). When you turn the truck on, Pin 86 receives power from your switched source, which then "activates" the relay. This in turn will connect pins 87 and 30 together, thus, powering your outlet.....
Ramius83 is offline   Reply With Quote
Switched Power Source Search – Back Up Camera Install mahoneyj Titan Visual & Audio Discussion 7 02-04-2006 06:22 AM
best place to steal switched power in rear of truck grunge311 Titan General Discussion 6 11-18-2005 03:17 AM
12-volt Power Outlets buzzkillwill Titan General Discussion 6 06-04-2005 07:59 PM
Power Driver Seat power off switch INSTALLED! Detail writeup! Titan_TX Titan General Discussion 6 11-21-2004 02:22 PM
Fuses for Power Outlets BIZZY5DOT0 Titan General Discussion 4 11-04-2004 07:09 PM
