I know this is like beating a dead horse I have come to this site and have tried everything possible to fix this issue.
Done brake calipers and rotors on the front thursday evening drove it home and it done fine however Friday morning I go to start the truck it spins over but will not start. I have replaced the following
Ipdm Relay
Ipdm Module
Fuel Pump
Crank Sensor
Anti Theft light flashes like normal
Installed the fuel pump connected the battery then plugged it up just to make sure it run. It came on so we installed the pump in the tank and went to start the truck and now the pump will not run. I have done the test for the IPDM and everything checks out normal horn,lights,wipers, fan etc. All fuses and relays are good checked every one of them, The fuse links on the positive cable are good as well? Any thing I could be over looking?
No codes Nothing with the scanner.
Spray it with starting fluid it will fire right up
ECM Fried?
Any suggestions will help
Ipdm Relay
Ipdm Module
Fuel Pump
Crank Sensor
ECM Fried?
