Re: E85 - Anyone running it?
I ran it for awhile. Might do it again after I get out of grad school.
Performance: I couldn't tell a difference. I did not get the chance to tow anything while I was using E85, so I do not know if the extra weight would have affected performance or not. Under normal driving I could not tell a difference.
Milage: My mpg average about 13.
Cost: I went a little deeper than mpg though and found that per mile, E85 cost about 17 cents, while normal 87 octane is about 13 cents per mile. Obviously, that's a difference of 15 dollars every 300 miles.
It was the last part that nessesitates (sp?) that I use regular gas. I do drive a bit for being in school, and being in school I do not make a lot of money. While a tank of gas cost less with E85, I was filling up more often, so the net cost was more for E85. This is expected though since it takes 1.4 times the amount of E85 to get the same amount of energy as regular gas. So unless E85 is considerably cheaper it will not be cost efficient.
I do hope that in the future E85 becomes more available and its price either stays the same (with normal gas going up) or that E85 would be cheaper itself. I really like the concept of E85, and I definately like giving my money to some corn huskers rather than some oil barons.
Bottom line: If you do not mind paying the difference, then use E85. The more the demand, the more that's produced, and hopefully that would drive the price down and availabilty up until an equilibrium is reached that is beneficial for everybody.
2005 Titan Crew Cab
Mods: Flowmaster 40 Series, K&N Drop In Filter, Cool Nismo Sticker
