Add a leaf - Nissan Titan Forum
post #1 of 16 (permalink) Old 01-10-2017, 05:24 PM Thread Starter
Cwright22's Avatar
iTrader Score: 0 reviews
Add a leaf
So I just came across these on Amazon and thought id share because it looks like a great deal, as well as ask a question.
Heavy Metal Lift Kits Nissan Titan 2.0" Rear Add-a-Leafs + Shims High-Grade HEAVY STEEL 2004 - 2015 Titan Lift Kit https://www.amazon.com/dp/B00L3OJC06..._ZFyDybMYJY2XT
So I guess the question is, should I replace shocks with ones that are for a lifted rear end?
If so, I can only seem to find shocks for 4" lifts. Whats out there for 2? Do you need anything else, like will this change the angle of the rear driveshaft too much?
What do you guys think?
Sent from my VS995 using Tapatalk
Cwright22 is offline
Advertisement
post #2 of 16 (permalink) Old 01-11-2017, 03:06 AM
iTrader Score: 1 reviews
Re: Add a leaf
Bilstein 5125 for 1-2" of lift.
Smccarty3 is offline
post #3 of 16 (permalink) Old 01-11-2017, 07:52 AM
LaxDfns15's Avatar
iTrader Score: 4 reviews
Re: Add a leaf
The Bilstein 5125's are 0-2" or 2-4" if you have 4WD. The guys at TAP auto can take care of you.
2008 PRO-4X KC
Looks and Sound: No chrome, Leveled, Black Rhino Sidewinder 18x9's, 275/70/R18 Nitto Terra Grapplers, OEM modded headlights, RF system+Two Kicker Comp 12's, LED lights inside and out
Performance: AirAid MXP, UpRev, JBA LT Headers, Cajun B Pipes, JBA catback, Dirt King UCA's, Bilstein 5100's
LaxDfns15 is offline
post #4 of 16 (permalink) Old 01-11-2017, 08:25 AM
LSturbointeg's Avatar
Re: Add a leaf
Pretty good price if you're looking for a budget setup. I ended going with Deaver C30's.
2008 Nissan Titan LWB
Suspension Front:~Maxtrac Spindles~PRG 1.5" Spacer~Radflo 2.0's~DirtKing UCA's~PRG Endlinks~SPC Cambolts~Moog LCA's~PRG Derlin Spacers~PROTHANE Bushing~
Suspension Rear:~PRG Deaver C-30's~4" Blocks~Bilstein 5125 Shocks~Crown Suspension Adjustable Shackles~Custom CJD Racing 60" Traction Bars~
Wheels/Tires/Brakes:~20x10-24mm Fuel Hostage~35/12.5R20 Atturo MT'z~Maxtrac Extended BrakeLines~Front/Rear CrossDrilled/Slotted Rotors~
Lighting~Blk LED Halo Projector Headlights~XenonVision 35W 6K HID Kit~FogLight 5 CREE LED~White Interior LED Kit~3157 Switchback LED Turn Signal~Amber 450LM Led 194~
Exterior~Black Tow Mirrors~Iron Cross HD Step Bars~Carbon Fiber Door Handle Covers~AeroSkin Hood Protector~Upper/Lower Custom Satin Black Mesh Grill w/ Stainless Hardware~Fuel OffRoad Grill Emblem painted Satin Black/Carbon Fiber~20% Tint~AVS In-Channel Visor~PU Front Bumper w/ Bumper Cap Mod~Textured Fender Flares~SatinBlack Rear Bumper~SD Chargers Hitch~
Audio:~Pioneer AVH-P4300DVD~7"(2) HeadRest Monitors~FocalK2Pwr 6.5" Comp Frt/Rear~Tusunami 1.2FaradCap~Thunder2300X 4ch~Thunder280 2ch~Custom Sealed Enclosure w/ Polyfill~2 12" KickerProCompR~Fully Dynamatt Doors/Floorboards~Digital LED Voltage Display Fuse Holder~Stinger Gauge Pwr/Grnd Amp Wire Distribution Block~Stinger Pro 4 Gauge Blue/Clear Power/Ground Battery Wire~4/2-Channel 4000 Series RCA Cable~Stinger 14-Gauge Audio Speaker Wire~
LSturbointeg is offline
post #5 of 16 (permalink) Old 01-11-2017, 10:13 AM
REDRUM's Avatar
Re: Add a leaf
mine settled close to an inch after a few months.. shouldnt need anything for driveshaft, unless you start getting vibration or slip after install.
Stance: Sittin Tall @ 46.5" Round 9" Lift.. 10" if she wears a skirt
Suspension: RC 6" Lift, 4x4 Coils, Bilstein 5100's, PRG UCAS & Sway Links,
CST CBDB, 4" Blocks/1" Helpers, Bilstein 5125's, AirLift Bags
Wheels: Ultra Crusher 20's wrapped with NTG 35"s, Bora 1.75" Wheel Spacers
Performance: BDGT, K&N Drop In Filter, Dual Exhaust FlowMaster knockoff
Audio: Alpine Head, 2 Kicker 10"s, Kicker Amp
Misc: Royalty Core Grilles w/ LightBar, RC Nerfs, Plastidipped badges, rear bumper,
Dbl Limo all around & 20% Windshield, Halo Projector Heads, Smoked tails & 3rd.
REDRUM is offline
post #6 of 16 (permalink) Old 01-11-2017, 10:34 AM Thread Starter
Cwright22's Avatar
Re: Add a leaf
Where do you find this set up? Cost? And what are the additional benefits over what I found?
post #7 of 16 (permalink) Old 01-11-2017, 11:33 AM
rambob's Avatar
Re: Add a leaf
If you are 2wd, the 4wd shocks are 2" longer. but might as well get the right Bills.
AAL when I had in my silverado made the rearend bouncy when unloaded. I find the titan is already pretty bouncy unmodified, when decelerating.
2006 Kingcab SE
08 4wd coils & pwm
35x12.5x18 Toyo OCMT
rambob is offline
post #8 of 16 (permalink) Old 01-11-2017, 12:21 PM
Re: Add a leaf
I've only heard good things with the Deaver's from PRG vs any other add a leafs.
You can get them from PRG $219: PRG Products These springs will provide approximately 3.5" of lift on a 4wd and approximately 2.5" of lift on a 2wd.
Or these $219: PRG Products
It gives you approximately 1.5" of lift on a 2wd or 2.5" of lift on a 4wd
post #9 of 16 (permalink) Old 01-11-2017, 12:26 PM
Re: Add a leaf
Combined with the Bilstein 5125's gave the Titan a well balanced suspension
post #10 of 16 (permalink) Old 01-11-2017, 12:49 PM Thread Starter
Cwright22's Avatar
Re: Add a leaf
Youhave a lift block in there too?
post #11 of 16 (permalink) Old 01-11-2017, 02:14 PM
Re: Add a leaf
4" block. Came with the 6.5" spindle lift. But I didn't want the Cali Rake look so that's why I got the Deaver's to level the truck.
post #12 of 16 (permalink) Old 01-11-2017, 02:15 PM Thread Starter
Cwright22's Avatar
Re: Add a leaf
4" block
So what did you do in the front?
post #13 of 16 (permalink) Old 01-11-2017, 02:22 PM
Re: Add a leaf
Hey, you're in Canton! I'm over here in Toledo... well Moncloca. Here's my build thread: LSturbointeg's 08' LWB Build!
Are you currently trying to lift your truck?
The Following User Says Thank You to LSturbointeg For This Useful Post:
Cwright22 (01-13-2017)
post #14 of 16 (permalink) Old 01-11-2017, 04:33 PM Thread Starter
Cwright22's Avatar
Re: Add a leaf
Thats sweet man. And yeah. Just a little and on a budget. I got the 2 inch leveling kit from rough country that I'm Going to put in. Got it to raise the truck a little, not to level. I'm ok with the height difference, thinking I wanted to add the same 2 inches in the rear.
post #15 of 16 (permalink) Old 01-12-2017, 06:38 AM
dreep's Avatar
Garage
iTrader Score: 2 reviews
Re: Add a leaf
If the Deaver C30's give a bit too much lift, take a look at the C10's. Available at PRG Products like the C30's, as LS said, or you can get them and other PRG stuff at PerformanceLifts.com, especially if you have problems getting in touch with PRG. I've had good luck dealing directly with PRG, others report major issues... PerformanceLifts just gives a good alternative to get the PRG products, which are quite good.
Cheers!
2014 PRO-4X
UpRev
dreep is offline
The Following User Says Thank You to dreep For This Useful Post:
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Add-A-Leaf BamBam13 Titan Suspension 12 09-11-2013 03:51 PM
Add-a-leaf renlo Titan Suspension 4 12-13-2011 10:24 AM
add a leaf? Bulldog22 Titan Towing & Hauling 5 07-21-2009 07:13 PM
Add-a-leaf? TexTitan04 Titan Suspension 8 01-12-2008 05:35 PM
Add A Leaf Eric Warner Pacific Northwest Forum 4 11-09-2006 02:32 PM
You may post new threads
You may post replies
