Old 04-04-2006, 07:38 AM   #1 (permalink)
d0va's Avatar
Lightbulb what am i missing out on? 4x4 texas edition what options am i missing?
I have a 2006 4x4 cc Titan is the Texas edition. I know i dont have the e-locker, and my truck didnt came with a tow hitch, but it has the "tow mode" switch??? what that the tow mode does? Also when i peel off a light turns on in the dash that says "slip", is the truck equipped (sp) with anti-slip mechanism i dont seem to have a switch to turn it off.
Can some one pls tell me what am i missing out by not having the e-locker? I dont plan to do alot of off-roading but eventually i will get her dirty and muddy, also i dont plan on towing anything @ LEAST FOR THE NEXT 5YRS dont have the money to buy it.
When the truck is running on 2 wheel mode does it pulls with two wheels? (if i do a burn out would i leave 2 stripes or just one ) I love this truck is a beast.
Pm for a Signature Request
Check out my Photoshop Signature Album
d0va is offline   Reply With Quote
Old 04-04-2006, 07:43 AM   #2 (permalink)
Supporting Vendor
P's Titan's Avatar
Re: what am i missing out on? 4x4 texas edition what options am i missing?
The slip on/off button should be on the lower part of the radio bezel by the tow mode switch. Sh!t I can't remember WTF the button says. That feature is sometimes cool incase you loose traction the truck will correct itself by braking to the area that lost traction.
my mods list
www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 04-04-2006, 08:15 AM   #3 (permalink)
baseballfanz's Avatar
If you have the Trac Package you don't have a switch to turn it off. The tow mode button just keep the rpm a little higher. When in 2 wheel drive only one wheel spin if your doing a burn out, Titan have an open differential.
Also, are you sure it's 4x4? I though the Texas Edition only come as a 4x2 unless they change that for 06.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 04-04-2006, 08:49 AM   #4 (permalink)
P's Titan is confusing VDC with ABLS. VDC applies the brakes and or cuts power to keep you from fish tailing etc. If you have it there is a switch near the tow mode switch.
As BBfanz says, there is no switch to turn of ABLS. It either works or it doesn't. Even when ABLS works the extra traction it provides is marginal.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 04-04-2006, 12:36 PM   #5 (permalink)
d0va's Avatar
im sure is 4x4 i have 4hi 4lo knob next to the ignition switch and no idont have another switch i only have the tow mode in the middle by itself. so what is that i have ABLS only? pls help...im confused what about the e-locker? what is it for
Old 04-04-2006, 01:13 PM   #6 (permalink)
BigA's Avatar
You can get the Texas Titan Package in a 4x4, somebody on here got a nice blue 4x4 with the Texas Titan package.
BigA is offline   Reply With Quote
Old 04-04-2006, 01:45 PM   #7 (permalink)
that's cool, not sure cause back in 05 they told me TX package was on 4x2 only.
Old 04-04-2006, 01:47 PM   #8 (permalink)
You probably have the Trac Package like me, no button to turn it off, if it detect one wheel spinning, it apply the ABLS to give the other wheel some power.
Old 04-04-2006, 02:12 PM   #9 (permalink)
You guys got the Texas package!!!! I want the Florida Rag top package!!!!
Now Gone but still Love em----------------07 2500 HD silverado 4 door
Old 04-04-2006, 02:28 PM   #10 (permalink)
d0va's Avatar
Talking Re: what am i missing out on? 4x4 texas edition what options am i missing?
you mean this one---->Pictures Of My 2006 Najestic Blue Tt
THanx for the input, is there a way to put an e lock to mine
Old 04-04-2006, 02:29 PM   #11 (permalink)
Supporting Vendor
P's Titan's Avatar
He said a slip light comes on, isn't that the VDC ? When I turn it off and peel out around a corner that light does not come on. When the VDC is on the slip light comes on and it brakes to were it is slipping.
Please respond if I still am "confused"
my mods list
CrankyWhore™
TequilaWhore™
Old 04-04-2006, 03:20 PM   #12 (permalink)
According to the manual the slip light will come on if either the ABLS or VDC is engaged. If you have ABLS the slip light should come on if you have one wheel spinning. I have had the ABS replaced in both of my Titans because they either wore out(first Titan), or was bad from the factory(2nd Titan).My ABLS is engaged(slip light on) about 10 times a day while driving on the ranch. Sometimes for 30 seconds or more at a time.
Also, on my 04 the light said BSLIP, while on my 05 it just says SLIP.
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
Old 04-04-2006, 08:06 PM   #13 (permalink)
From reading the difference thread and forums, not sure sure what the difference is but I know those with VDC package can turn it off, those that have the Trac Package are unable to turn it off.
Old 04-04-2006, 08:18 PM   #14 (permalink)
I don't think you have the trac package either, I went to Nissan USA website and did a build your Titan thing. When selectng the trac package on a 4x4 they made me change to 4x2. You can only get VDC with the side airbag package.
Old 04-05-2006, 05:43 AM   #15 (permalink)
d0va's Avatar
im so confused now, I have the window sticker would it tell me there what options i have or is there another way to find out.
Starting - missing on the first try... Spranger Titan Problems & Dealer Service 1 01-26-2005 08:20 AM
missing part jhromy Titan General Discussion 4 01-22-2005 09:35 PM
Lumbar missing??? cajunjimbo Titan General Discussion 18 07-21-2004 02:41 PM
Missing part? Tattoomee Titan General Discussion 7 06-04-2004 10:18 AM
Missing moulding? LastHurrah Titan Problems & Dealer Service 4 04-11-2004 10:40 AM
