ECU reset turned off 'Service Engine Soon' light - Nissan Titan Forum
post #1 of 13 (permalink) Old 04-16-2006, 10:00 AM Thread Starter
iTrader Score: 0 reviews
The light came on for the second time since I've owned the truck... only this time it didn't go off. There is a lot of info to search through and this may be in there somewhere. Anyway, it saved me a trip to the dealer.... thanks guys!
BTW... I just did a search for 'ECU reset' and it popped up. The 'easy method' that has been edited into the link is super easy... I just printed it out and sat in my truck.
mtofell is offline
Advertisement
post #2 of 13 (permalink) Old 04-16-2006, 10:19 AM
Supporting Vendor
P's Titan's Avatar
iTrader Score: 4 reviews
Re: ECU reset turned off 'Service Engine Soon' light
congrats!!! somone who searched and found an answer... what a concept
Did you determine what cause the SES ?
my mods list
USE DISCOUNT CODE FOLGER
FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
TequilaWhore™
P's Titan is offline
post #3 of 13 (permalink) Old 04-16-2006, 11:56 AM
Banned
you might want to invest in a code reader so you can see what code you are getting, as well as reset it with the tool.
Titan1219 is offline
post #4 of 13 (permalink) Old 04-16-2006, 12:17 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
Agree, code pop up for a reason. Resetting your ECU might make the SES light go away but the problem is still there.
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #5 of 13 (permalink) Old 04-16-2006, 01:34 PM
scr38's Avatar
You don't need to purchase anything to read out the code and reset the light.
1. Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
2. Fully depress and release the accelerator pedal five times in less than five seconds.
3. Wait seven seconds, then fully depress the accelerator pedal for ten seconds until the SES light flashes.
4. Release the accelerator pedal and count the flashes to obtain the four-digit code.
5. Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
6. The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits. Count these blinks to complete the four digit code.
7. The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
8. If you get four blinks of ten (0000), the ECM is indicating no malfunction.
9. Clear the code by holding down the accelerator pedal for more than 10 seconds while the SES light is blinking. When you release the pedal, the ECM erases the trouble code(s).
scr38 is offline
post #6 of 13 (permalink) Old 04-16-2006, 03:12 PM
Banned
usually you will get the book with the tool that tells you what the codes actually mean, so that can help a lot.
post #7 of 13 (permalink) Old 04-16-2006, 03:20 PM
You could also go here, http://www.troublecodes.net/OBD2/
Also alot of autoparts place can pull the code for free.
post #8 of 13 (permalink) Old 04-16-2006, 04:41 PM Thread Starter
Thanks guys... I will probably just let dealer figure it out when I take it in for the 30K service in a month or so. That's the second time its lit up.... as mentioned, the last time it went away on its own. Do you think the dealer will be any help? Or is it one of those 'if it's not doing it now, we don't care' things? Any idea if the codes are stored for the dealer to read. It would be nice to know going in that I can make them look into it.
mtofell is offline
post #9 of 13 (permalink) Old 04-16-2006, 07:18 PM
Supporting Vendor
P's Titan's Avatar
I don't think the code drops untill what ever is wrong is fixed. I may be wrong about that. My light went on and off and dealer read the code long after the light went off
my mods list
CrankyWhore™
TequilaWhore™
post #10 of 13 (permalink) Old 04-16-2006, 08:10 PM
Banned
they are stored. Not sure if its permanent until erased,but i think so. if the problems comes back, the light will go back on, but if the problem goes away, light stays off, but code is stored in memory.
post #11 of 13 (permalink) Old 11-14-2009, 03:52 AM
Smile Re: ECU reset turned off 'Service Engine Soon' light
A big thanks from Edinburgh, Scotland to the retired gentleman in Lake Jackson, TX. I had a problem with the SES light on my 2002 Nissan X-Trail after replacing the cat oxygen sensor and I had no idea how to fix the problem. I searched the X-Trail forum for ideas but most of them involved disconnecting the battery or removing two or three fuses. I tried these methods but the light just kept on shining !! So I searched other forums and found the Titan one. I followed the instructions to the letter (very important) and SUCCESS. The light is now out and I can enjoy driving the car again. So again a big thanks to you guys and keep up the good work. Kind regards from bonnie Scotland.
Fixitjimmy is offline
post #12 of 13 (permalink) Old 11-14-2009, 04:35 AM
Thanks to the data and members on this forum I had to do the same thing to my 08, SE when the SES light lit up around 14,000 miles. The blinking light was an EVAP code when I looked it up and I cleared it. The gas cap was not loose, and it happened about 3/4 of the way through a full tank. The same thing occurred around 1400 miles and the dealer told me the gas cap was loose so I asked them to check it and it was tight. Then they told me it was due to me topping off the tank after the nozzle clicks the first time (which I quit doing as well). In my case the forum was helpful because the dealer is a 50 minute drive each way.
kornegk is offline
post #13 of 13 (permalink) Old 11-14-2009, 06:10 AM
layer1's Avatar
Garage
iTrader Score: 9 reviews
This week I finally filled up after 3 weeks and I topped it off to the top. For the first time I heard the air trying to escape (like someone chugging water). I waited for few minutes for the sound to go away before putting on the gas cap.
08.5 SE CC, 4x4, Smoke
My Garage
Link to my Mod's
layer1 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Read and Reset the Service Engine Soon (SES) light TitanDoug Titan FAQ & How to Area 30 11-21-2014 04:51 PM
Service engine soon light BLIZZARD XE Titan General Discussion 5 08-18-2005 01:45 PM
Service Engine Soon Light hoffmase Titan Problems & Dealer Service 0 12-10-2004 10:48 AM
Service engine light...again? TranMan409 Titan General Discussion 2 07-31-2004 09:35 PM
Reset service engine soon light? Ltdan Titan Problems & Dealer Service 1 05-26-2004 11:35 PM
You may post new threads
You may post replies
