Stuck in Limp Mode After Power Outage - Nissan Titan Forum
post #1 of 5 (permalink) Old 04-12-2017, 06:17 PM Thread Starter
iTrader Score: 0 reviews
2004 Titan - Turned my engine off and my trailer brake control clicked and flashed. It seemed like an electrical issue so I went to start it and there was absolutely no power. My battery had been groaning a bit on start prior to this. Jumped the battery and two hours later it started fine so I drove home from work. No pick up - obviously the truck was stuck in 3rd gear with no pick after a full stop. I replaced the battery and the truck starts better than ever. However, I'm still unable to get it out of fail safe mode. Any help is appreciated. No codes are showing up either.
bissy is offline
Advertisement
post #2 of 5 (permalink) Old 04-12-2017, 08:14 PM
4mula1fan's Avatar
Garage
iTrader Score: 3 reviews
Re: Stuck in Limp Mode After Power Outage
Unhook the negative cable overnight, and then see what happens.
TrainingWheelsWhore™
08 Pro4X
Wife's ride '12 Maxima S Limited Edition
2013 Coachmen Catalina 252RLS Santara Series
4mula1fan is offline
post #3 of 5 (permalink) Old 04-13-2017, 05:21 PM Thread Starter
Thank you! I will try hat tonight.
bissy is offline
post #4 of 5 (permalink) Old 04-15-2017, 09:54 AM Thread Starter
Unhooked battery overnight. No change. What's strange is the truck runs great once you get speed up - even at highway speeds. No codes. No apparent electrical issues. Small hole in muffler. Could this be a factor?
bissy is offline
post #5 of 5 (permalink) Old 04-20-2017, 09:37 AM
If you mean not all the gears are avail,(still stuck in third?) then the Trans is being sent 'limit' instructions from the ECU.....that may indicate a re-flash or replacement is needed.
If by limp mode, you mean limited to 2500RPM, check the MAF against the service manual spec using a multimeter. I'm aware of situations where a MAF was malfunctioning without setting codes.
For the future, pull the trailer brake controller and set in the glove box when not towing. It's throwing current with no where to terminate every time you brake...even when putting the trans into park, and who knows what that does if you have bad ground somewhere, or an eddy current builds in your electrics and zap....something fries. It's a straight twelve volt in and out. Sensors, and the internals of the ECU's are running on mostly less than twelve volts(3-5 volts usually) at the circuit board or component part.
Nick Name is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Transmission stuck in 4th GEAR/LIMP MODE P1564 titanridinghigh Titan Engine, Transmission & Drivetrain 4 09-11-2015 07:08 PM
Limp mode Joflor1985 Titan Engine, Transmission & Drivetrain 1 07-08-2014 06:36 AM
tranny check light stuck in limp mode datsun 30 Titan Engine, Transmission & Drivetrain 0 03-01-2012 07:58 PM
limp mode??? INSSAN04 Titan Problems & Dealer Service 5 12-19-2009 05:51 AM
limp mode risingsun Titan General Discussion 16 10-27-2008 12:45 PM
You may post new threads
You may post replies
