07 Titan abs/slip light - Nissan Titan Forum
post #1 of 2 (permalink) Old 04-19-2017, 06:06 PM Thread Starter
iTrader Score: 0 reviews
Abs/slip light and 4 wheel drive won't engage. What's the easiest way to confirm the issue? I'd like to avoid getting raked by a dealership to read a code. Assuming one of the wheel speed sensors is bad.
Sent from my SM-N920P using Tapatalk
N8tureboy is offline
Advertisement
post #2 of 2 (permalink) Old 04-20-2017, 09:48 AM
Re: 07 Titan abs/slip light
Carefully remove the rear wheel abs sensors and clean them. They are notorious for getting crudded up from brake dust and malfunctioning. While they're out, use a bright flashlight and while you rotate the wheel hub, look down the hole at the tone ring just to be sure no teeth have been broken off. If that doesn't work, do the same to the front. Chase the wires back to the the first connector for each and separate, then put some dielectric grease in one side of each and fully reconnect. This will prevent any water intrusion or contact corrosion in the future so you avoid that easter egg hunt down the road. If you have a multimeter, check the OHM read for each. Open, replace. I don't recall of the top of my head what the acceptable OHM range is, but usually it's and open that fails the sensor. Someone else may have that number or it's definitely in the service manual.
Still have a problem after that, there should be a U code in the ECU. Pull the fuse for the ABS pump and re insert to hard boot the system....sometimes that will fix. If not, you'll most likely have to spend to get the U code pulled so you know where the problem is.
Nick Name is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Diff lock - slip light on... Then abs-slip light-vdc light on TitanPro42012 Titan Engine, Transmission & Drivetrain 7 02-07-2017 03:57 PM
SLIP LIGHT> ABS LIGHT> Check Engine Light????? Cricket7 Titan General Discussion 25 05-07-2016 06:44 AM
ABS/Slip Light - is ABS deactivated? derektitan Titan Wheels, Tires & Brakes 1 11-08-2015 01:27 PM
Abs/slip light on!!! IRONMAN Titan Engine, Transmission & Drivetrain 2 08-25-2015 09:45 AM
2005 Titan SE 4x4 Slip and ABS light question markwalsh12345 Titan Wheels, Tires & Brakes 9 04-25-2013 07:51 AM
You may post new threads
You may post replies
