Hose for brake bleed nipple - Nissan Titan Forum
post #1 of 5 (permalink) Old 04-19-2017, 07:27 PM Thread Starter
iTrader Score: 0 reviews
I realize I'm probably putting way too much thought into this, but I've searched all over the forums, as well as Google, and can't find what diameter of fuel hose I should buy to fit on the brake bleeder nipple so I can, well, bleed the brakes, OBVIOUSLY!
Barry King is offline
Advertisement
post #2 of 5 (permalink) Old 04-20-2017, 09:58 AM
Re: Hose for brake bleed nipple
slip the smallest socket that will still go over the nipple head. Then go to the local hardware or big box and buy the same or slightly smaller ID clear hose. You're good to go.
Nick Name is offline
post #3 of 5 (permalink) Old 04-20-2017, 10:49 AM Thread Starter
Told you I was overthinking it! Thanks for the lesson in common sense!
post #4 of 5 (permalink) Old 04-20-2017, 04:43 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
Don't use fuel hose. Use clear plastic. You need to be able to see the fluid as it comes out so you can see the color of the fluid as well as the bubbles in the fluid.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #5 of 5 (permalink) Old 04-21-2017, 10:45 AM Thread Starter
Based on Nick Name's suggestion, I'm headed out for 1/4" tubing.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
2008 Nissan Titan Driver tire scrubbing brake hose? JohnWalt New Member Introductions 4 10-05-2016 09:54 AM
? when should i brake and bleed during supsension lift? LSturbointeg Titan General Discussion 1 09-08-2016 01:37 PM
Brake Bleed Nipple pipho Titan Wheels, Tires & Brakes 2 01-18-2011 02:55 PM
Does it matter when I change/ bleed brake fluid? joseph143 Titan Wheels, Tires & Brakes 5 11-30-2010 07:43 AM
Is there a way to bleed the brake lines..... shawn474 Titan Wheels, Tires & Brakes 8 09-23-2010 02:24 PM
You may post new threads
You may post replies
