Old 03-28-2007, 05:55 PM   #16 (permalink)
HudsonValleyTitan's Avatar
Re: Popping noise from front end
My guess is the sound is actually from the hitch itself. The sound/vibration can travel through the frame, making it seem to come from another source.
- Joe
Old 03-28-2007, 05:56 PM   #17 (permalink)
Originally Posted by quadcab
I have a PRG 2" leveling kit installed, and occasionally pull my buddies 10,000lb Searay. I have had no problems. We dropped it in the water laast weekend and all seemed well.
Jeez...how big is his SeaRay that it weighs 10k?
- Joe
Old 03-28-2007, 05:56 PM   #18 (permalink)
jbaltimore's Avatar
I am getting the same noise. Stipped it all down greased it all and its still doin the pop deal. I can feel it in my feet and hands. Must be the strut
jbaltimore is online now   Reply With Quote
Old 03-28-2007, 06:07 PM   #19 (permalink)
I'm positive mine is coming from the front.
SKEET is offline   Reply With Quote
Old 03-28-2007, 06:09 PM   #20 (permalink)
And it happens only when towing? Strange then.
- Joe
Old 03-28-2007, 06:27 PM   #21 (permalink)
StuntDriver06's Avatar
play in the hitch or poorly lubricated hitch balls will make popping noises, and being that the hitch is effectively a part of the full boxed frame, the sound/vibration could be traveling up the frame a considerable distance.. i experienced this using a 2 inch ball and a 1 and 7/8 hitch... thought the front end was going to fall out from under the truck....
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 03-28-2007, 07:50 PM   #22 (permalink)
That's what I was saying. Happened to me.
- Joe
Old 03-28-2007, 09:03 PM   #23 (permalink)
I didn't say it only happens when towing.It doesn't matter if I'm towing are not.
Old 03-29-2007, 02:58 PM   #24 (permalink)
In post #19, you countered my answer to the original poster about it being more probable that it's coming from the hitch because it only happens to him while towing. I assumed, because of your answer, that you had the same issue. Yours then, is not related to towing as his is. Sorry.
- Joe
Old 03-29-2007, 05:33 PM   #25 (permalink)
Shane06fl's Avatar
I thought it was the front too and could feel it in my feet. For the life of I couldn't figure it out. I called up the service scheduler at the dealership and asked him if he had any other problems like this so I could fix it myself (I don't mind) he said to look at the two bolts that hold the rear trany mount to the trany.WHAT? well sure'nuf one of the bolts had backed out and was jammed on the cross member. I called him back and said bring it in now if I could. I did, took the tech about 20 minutes to replace both bolts. Then he spent another 45 minutes checking every nut and bolt he could find under there. Then he said he didn't like Nissan's POS axle vent and installed new fitting and put a hose to it. Told me to install a small fuel filter to help keep dirt out. There is a do it yourself on the same fix here on TT. BTW that valve is not a check valve, it is open hole right to the axle.
Sorry about that, check you trany mount bolts where the trany and TC meet.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Shane06fl is online now   Reply With Quote
Old 03-29-2007, 06:14 PM   #26 (permalink)
not a check valve... say it isnt so..... sounds like you have an awesome dealer...
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 03-30-2007, 09:51 PM   #27 (permalink)
I checked my tranny bolts and they're tight.I don't know what else to look for.
Old 03-30-2007, 11:09 PM   #28 (permalink)
After further inspection I cav see that I have marks on my coilbucket.Is there anything I can do to stop it.
Old 03-31-2007, 11:31 AM   #29 (permalink)
What's a coilbucket first off...lol. I guess I need to climb under the truck and keep an eye on things.
- Joe
Old 03-31-2007, 07:46 PM   #30 (permalink)
titan2005's Avatar
my 07 was popping when crossing over a speed bump or just shifting the weight of the truck like when you pull out from a stop sign and turning ! BUT took it to the stealer yesterday and they found the cause it was a (TOP MOTOR MOUNT BOLT) they said there was a TSB out on it just take the bolt out put teflon tape on threads and antisieze on it ? so far have not heard it again ! anyway another reason i had it there was the chip spot on my dash they ordered a new piece and replaced it also BUT did a horrable job replacing it they scratched my truck all over the inside ALOT worse than the one i took it in for. needless to say i was HOT, you can tell where they took a screw driver or something to pry the piece out and on the passanger side where he opened the dash to get the piece out he must have leaned on the dash now i have a gap on the left side at the top of the dash when you close it. he got grease on the drivers seat and on both floor mats. i called them when i got home and told them that is unexcuseable it's so pathic i can't describe it. how would this tech feel if he took his new truck in and somebody scratch it up and got grease all over it? i'm done now had to get this off my chest lol.
2007 CC SE 4X4 BT MAJESTIC BLUE
titan2005 is offline   Reply With Quote
Front End Noise AVI8TER Titan Suspension 7 02-17-2006 05:35 AM
Klunk Popping noise under passenger floorwell Tviper35 Titan Problems & Dealer Service 5 01-13-2006 01:29 PM
Popping Noise When Turning JWILLS Titan General Discussion 30 08-19-2005 08:31 PM
Fixed mysterious popping noise tnbowhunter Titan General Discussion 22 01-14-2005 08:03 AM
Noise from front wheel well? skycruiser Titan Problems & Dealer Service 6 10-28-2004 08:20 PM
