Does anyone know if the spare has the air pressure sensor in it? And could I use it to permanently replace one of my wheels?
Yes you can use it as a permenant wheel but you have to have the sensor moved from the tire you're replacing to the spare......the spare doesn't have one.
- Joe
NEW - 2008 Blizzard Titan CC PRO-4X OFF ROAD LWB w/TOW, UB & RF pkgs w/XM & Bluetooth handsfree phone system, Nissan bug deflector, Under seat storage box, Nissan factory step rails, LED taillights, Line Of Fire LED Light Bar, Chrome Door Handles, TomTom GO 700 GPS, Extang Tuff Tonno.
I believe you have to unscrew the nut on the valve stem and push the sensor into the tire. Break the bead on the rim/tire and retrieve the sensor.
You are exactly right!!!!
2001 Polaris Sportsman 500.
if you are looking for a sensor I have a few extras. Basically you have to break the wheel down and it completely replaces the valve. Any tire shop could do it.
What a PITA! You have to actually remove the tire to replace it? I just thought it was a skinny thing that would fit right through the valve stem hole. Hope it never goes bad!
No, you don't have to remove the tire. Just break the bead and you can get it out. (like was mentioned above)
