Old 04-30-2006, 12:35 PM   #1 (permalink)
Undercover Tonneau Fit?
I had dealer install my Undercover with the bracket system for the util- rack and I am not sure about the fit towards the front of the cab. You guys that have this set up: does it look like the cover is not flush against the bed rails? My cover has at least a 1" gap from the front of the bad to the cover and sticks out on the sides more than I think it should. The fitment towrd the rear is fine. I have tried to tweak the front brackets, but there is not any movment or aligning to be done. I have been getting a bad vibration that sounds like it is coming from the top when I'm on the highway and traveling at 65-70 mph speeds. I think it is coming from the top (shuddering)? Anyone else having these issues?
BSIMPSON is offline   Reply With Quote
Old 05-01-2006, 06:53 AM   #2 (permalink)
Re: Undercover Tonneau Fit?
I would be interested in knowing this also, as I was planning on purchasing one soon. Hope someone has the answer.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
bbomar is online now   Reply With Quote
Old 05-01-2006, 07:36 AM   #3 (permalink)
nthomp16's Avatar
I have had the undercover on my 04 CC for about 2 months now, and I think that a little space at the front between the cab and the bed is normal...you have to have a bit of space to make room for the tabs that attach the cover to the rails. Also, look at the gasket along the front rail. I know that you are supposed to have it out, rather than under the cover, but it is such a flexible material that it vibrates very bad from the wind...I think this is what you are hearing. I simply tucked mine under the cover and hav ehad no problems with noise or leaking since.
nthomp16 is offline   Reply With Quote
Old 05-01-2006, 10:26 AM   #4 (permalink)
Send a message via AIM to rodney
i just installed mine. i have allmost no space up front, after setting the gap in the back of the it. in fact, i had to put duct tape on the little circlips, as they rattled against the cab and wore through the paint. aside from that, the cover is awesome!
*edit: on a sidenote, i just got mine last week from Luke at www.truckalterations.com for $650 shipped. this was for a CC w/utilitrack.
rodney is offline   Reply With Quote
Old 05-01-2006, 10:47 AM   #5 (permalink)
On my F150 I had the vibration problem so I called David Lyons at Undercover. He said that the fix for the noise is to trim about ¼ inch off the front seals flap, its hitting the back of the cab and causing the noise.
He was very helpful and had the answer right away. I saved his info in case I needed it again so here is the phone number 1-866-900-8800.
killertitan is offline   Reply With Quote
Old 05-01-2006, 11:02 AM   #6 (permalink)
EricCartmann's Avatar
Send a message via AIM to EricCartmann
mine has what looks like a gap but it holds out water just fine.
2006 CrewCab LE 4x4 Galaxy Black
Born: 12/05
Purchased: 01/19/06.
OEM: BigTow Pkg, OffRoad Pkg, Side Airbag Pkg, Navigation, DVD, MoonRoof, Utilitrack w/ Bed-Ext.
AfterMarket: S50 Sirius Radio, UnderCover Tonneau, UWS Stainless Step Bars, VolantGen3 Intake, PowerAid TBS, Rancho Lift Kit, Helo Maxx6 17x9" Wheels, BFG All Terrains KO's 315/70/17, MagnaFlow Custom Exhaust, Security System: Sig P229 .40 cal
EricCartmann is offline   Reply With Quote
Old 05-01-2006, 02:11 PM   #7 (permalink)
Elbo's Avatar
Send a message via MSN to Elbo
Mine has almost no gap either. You can adjust the whole cover front to back, and side to side. When I first got mine own, I had it to far to the right, and it ended up rubbing the paint on the Left side. It's pretty easy to adjust. There is probably about 1 to 1.5 inches of play in all directions that you can adjust it.
Elbo is offline   Reply With Quote
new Undercover tonneau tccart Canada Forum 2 02-23-2006 05:46 PM
FINALLY - Undercover Tonneau PuvMan Titan Parts & Accessories 11 02-22-2006 08:09 AM
UNDERCOVER Tonneau PuvMan Titan Parts & Accessories 1 01-27-2006 02:55 PM
UnderCover Tonneau Installed m0wens Titan Parts & Accessories 5 07-08-2005 03:22 PM
Undercover Tonneau Review npep Titan Parts & Accessories 7 04-30-2005 09:18 AM
