Old 05-29-2006, 06:21 PM   #1 (permalink)
Banned
Exclamation Do I Need to Use a Spring Compressor to Adjust DR Coilovers?
Now that the coilovers are on I can't adjust them. I see they have one lock, which I unlocked and then I heaved with the spanner wrench but couldn't move them. I didn't want to use a bar or too much force in case damage the threads.
Do I need to compress the springs to adjust them?
Also I got 1" of thread showing. I assume I need 1and 3/4 " thread for 2and3/4" lift
TitanPSD is offline   Reply With Quote
Old 05-29-2006, 06:45 PM   #2 (permalink)
rcantu's Avatar
Re: Do I Need to Use a Spring Compressor to Adjust DR Coilovers?
you can do it w/o a compressor. you should take the wheel off for better leverage since you're not lifted. I did mine w/ the wheels on but Hooligan laughed at me. It was a PITA if you want to lift it. To lower it's not as bad to lower it.
pics of the Titan
Old 05-29-2006, 06:50 PM   #3 (permalink)
dareed02's Avatar
Exactly, take the wheel off. It is so much easier that way. Also, add some type of spray lubricant to the top of the springs and at the bottom. Let the lube sit for about an hour and then re-apply. If you don't, you will have a very hard time with the wrench. I used a 5lb sledge to help turn the spanner wrench at first and then was able to spin it using my hands (and the spanner wrench, of course). Have fun!
Traded my Titan but will buy another soon!
dareed02 is offline   Reply With Quote
Old 05-29-2006, 07:33 PM   #4 (permalink)
Banned
Ok, I put some muscle into it tomorrow w/a pipe.
Was going to today but wanted to check if OK.
Adjustment, God willing, to 1and3/4" thread for 2and3/4" lift and I still got a healthy rake
Old 05-29-2006, 08:40 PM   #5 (permalink)
rod_b's Avatar
A tip Greg gave me was to shoot the threads with some WD40 and it makes it easier. I found it easier just using the straight side and cranking it in smaller increments rather than using the curved end.
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 05-29-2006, 09:10 PM   #6 (permalink)
kartman's Avatar
I did it a few times with out a compressor and the wheels on the truck. A little WD40 and they are good to go.
Rebar Wrangler
How would always running A/C compressor effect gas economy? Triple S Titan General Discussion 11 03-17-2005 06:47 AM
Adjust Sunroof JMark Titan General Discussion 1 03-11-2005 06:37 PM
Air Tools and Compressor Khamburg Off-Topic Discussion 9 02-26-2005 06:45 AM
Air compressor purchases from 1996-2004 Bayou Titan Off-Topic Discussion 12 01-22-2005 10:36 PM
Defroster on- AC Compressor on? RememberThisTitan Titan General Discussion 22 10-10-2004 12:03 PM
