Old 07-10-2006, 11:13 AM   #1 (permalink)
Banned
Send a message via Yahoo to TexasTitan05
Engine Cleaning 101
Hey Y'all... I just cleaned my engine this weekend with Simply Green, and that stuff works wonders. I have a question for all of you that use Simply Green, and clean your engines on a regular basis. Is it OK to clean your engine every week? Or, should this be more of a bi-weekly thing, or once a month thing? I'm also looking for someone who can paint by engine cover in the Houston area; or I might do it myself. Has anybody done that, and if so, is it fairly easy? Thanks for the feedback !!
TexasTitan05 is offline   Reply With Quote
Old 07-10-2006, 08:38 PM   #2 (permalink)
BigRedTitan's Avatar
Re: Engine Cleaning 101
I don't spray my engine too often. I do use Simple Green when I do. I have only sprayed mine twice in the 2+ years that I have owned my Titan. I usually just wipe it down with a dry microfiber towel.
As far as someone to paint your cover, I don't know. If you want to do it yourself, just clean it really good, remove and/or tape off what you don't want painted and spray light layers of paint. It doesn't necessarily have to be High Temp paint. After driving your Titan for a while, you can still lay your hand on the cover and not get burned, it's just warm.
Here's mine...
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1½" Rear Blocks, Bilsteins Front & Rear,
LED's Front, Eagle Eyes LED Tails, JDM 6000K HID Lows & Fogs, SilverStar Halogen High-beams, LED Third Brake Light, Red Billet Aluminum Oil Cap,
Red Active Tuning Grounding Kit, Body Colored Front Spoiler, 2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 07-10-2006, 10:38 PM   #3 (permalink)
moore101's Avatar
I wouldn't clean a engine any more than once every 3 to 6 months. There are way to many electrical components and sensors to get water into.
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
moore101 is offline   Reply With Quote
Old 07-11-2006, 09:39 AM   #4 (permalink)
ttugrad95's Avatar
I wouldn't see a problem with just hosing it off to get the dust off but I wouldn't use any kind of detergents too often. I would be afraid that even with just simple green it could start to take its toll on the hoses and seals.
If your not the lead dog, the view never changes.
ttugrad95 is offline   Reply With Quote
Old 07-12-2006, 11:29 AM   #5 (permalink)
FLfinfan's Avatar
My engine is very dusty. I would love to clean it up some. If I do spray it down, do I have to cover or plastic bag anything to keep it from getting wet?
FLfinfan is offline   Reply With Quote
Old 07-12-2006, 11:36 AM   #6 (permalink)
Banned
I couldn't see anything sticking out that would make me wrap it up per-se. I sprayed Simple Green on it, let it sit for a couple of minutes, lightly wash it completely off. I even sprayed SG on it again, and sprayed it off... Make sure that you have something to dry off your engine with. I used a leaf blower, it took a matter of minutes with that thing. My truck started right up, w/o any problems; so the water didn't damage anything. You may want to see if someone else will chime in on this to prove me otherwise.
Old 07-12-2006, 12:44 PM   #7 (permalink)
sedonaguy's Avatar
heres a tip, give the engine a good cleaning about twice a year whether it be simple green or the carwash engine cleaner. but in between those cleaning about every 4-6 weeks i spray engine compartment with armor all tire foam to keep the all the hoses and plastic nice and plyable, and then just wipe it down with a rag. it also looks nice ans clean too....works for me....
sedonaguy is offline   Reply With Quote
Old 07-12-2006, 01:50 PM   #8 (permalink)
StuntDriver06's Avatar
everytime i go to the car wash i open the hood, hose it down with tire cleaner let it set while i soak tires, come back and high pressure rinse the engine, dont forget the underside of hood, then i close the hood and let truck idle while i do rest of truck... always have done this and never had a problem, your sensors are not going to get wet, the connectors are waterproof to a point and letting the truck idle will let it dry, dont you think your tranny connectors and abs wheel sensors get wet when it rains?
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 07-12-2006, 01:56 PM   #9 (permalink)
ttugrad95's Avatar
Yeah, worrying about things getting wet pretty much ended when cars stopped using points. It takes a ton of water to kill the engine, you pretty much have to submerge it. Hose the crap out of it and drive it off.
Old 07-12-2006, 03:51 PM   #10 (permalink)
Blackin's Avatar
Heh, never thought about the tire foam. I'm gonna try that next time I wax my truck.
'09 Nissan Titan KC in "Brawn Red" - R.I.P. (Totalled!!)
*Superchips Cortex(Performance Tune)
*Volant CAI // Pic 2 // Pic 3
*Magnaflow(14568) X-pipe muffler w/duals out the back // Pic 2
*Stainless double-wall slanted tips // Pic2
Video Clip
Blackin is offline   Reply With Quote
Old 07-12-2006, 07:31 PM   #11 (permalink)
Tire foam also does a great job on the wheel wells. Just spray the liners, frame, leaf springs, A-arms, anything you can see. Then give it a wipe down and it will look better than when you drove off the lot.
Bryan
Old 07-12-2006, 11:13 PM   #12 (permalink)
baseballfanz's Avatar
I only use SimpleGreen when it get real dirty and I need to break up some junks in there. Otherwise I just wipe it with a wet rag.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 07-13-2006, 05:51 AM   #13 (permalink)
Blackin's Avatar
I've done ArmorAll Wheel Foam on the wells and the rear axle and springs. Just never crossed my mind to do the engine compartment. Really good idea honestly. One of those so simple, you just don't think about it I guess.
Video Clip
Cleaning Engine regwood79 Titan General Discussion 21 02-04-2006 10:57 PM
Engine pulsing under engine breaking in 1st gear migliore Titan General Discussion 6 10-25-2005 06:30 PM
Engine cleaning Bayou Titan Off-Topic Discussion 0 07-02-2004 08:27 PM
Engine Cleaning? Big Platinum Titan General Discussion 14 06-26-2004 12:34 AM
