Old 07-10-2006, 05:02 PM   #1 (permalink)
mdaigle's Avatar
4x4 OEM COILOVERS
i have a 4x2 CC '06 with a prg 2.5/1.5" mini-lift. i noticed after parking next to a 4x4 with a mini -lift this weekend that he was higher than me and that was with a 2" lift up front. i did a search and stock for stock the 4x4 OR package is 1.5" higher than the 4x2(in the front). my question is could the oem coilovers from a 4x4 be installed on a 4x2 ( with the 2.5" spacer) to gain an additional 1.5" of lift. i know a lot of people just throw away the oem coilovers when they get the aftermarket ones so this could be a cheap way to get an additional 1.5" of lift for someone with a 4x2. what do you guys think?
'06 SE SMOKE CREW CAB
BIG TOW
TRAC PACKAGE
PRG MINI-LIFT 2.5/1.5
mdaigle is offline   Reply With Quote
Old 07-10-2006, 05:09 PM   #2 (permalink)
Sammy Sandbag's Avatar
Re: 4x4 OEM COILOVERS
I think you'd get a rougher ride without all the added weight of the 4x4. Probably better to stick to something aftermarket. I'm sure Greg can give you the details.
-Counsel Yourself
Old 07-10-2006, 05:19 PM   #3 (permalink)
mdaigle's Avatar
so what do you think greg? a go or a no-go! if you think this would work( i don't mind a firmer ride-even with the 2.5" spacer up front the ride is still plush) how much would it cost me for a set of oem coilovers from an '06 OR 4x4 that you might have laying around your shop. let me know!
BIG TOW
TRAC PACKAGE
Old 07-10-2006, 06:19 PM   #4 (permalink)
You do realize that the spacers don't effect the stiffness (spring rate) of the ride at all? What you propose doing would. They use a stiffer spring to offset the added weight of the 4x4.
Of course this is all IMHO and IIRC, so Greg would be the source.
-Counsel Yourself
Old 07-10-2006, 07:27 PM   #5 (permalink)
mdaigle's Avatar
no doubt sammy! when i had my tundra, people were doing this oem 4x2 coilover swap for the 4x4 TRD coilovers just to level their tundras . the ride was compromised somewhat but not unbearable. however, the tundra and the titan are two different animals( the titan being the heavier animal in this case). i thank you for your input and respect your opinion, as one of the moderators on this forum you guys have a wealth of knowledge which i am thankful you guys share with us.
BIG TOW
TRAC PACKAGE
Old 07-11-2006, 05:46 PM   #6 (permalink)
It might not be that big of an issue, since I can't speak from experience, I just wanted to make sure you knew there would be a difference. I know greg will (well used to at least) make custom height spacers. Another issue you'll run into is the upper A-arm contacting the coil bucket. Without the TC arms (and possibly shaving the bucket) that's a very real issue when going too tall with spacers (or coilover replacements.)
-Counsel Yourself
F/S dr coilovers..... rookieTITAN Buy/Sell 23 05-29-2006 07:37 PM
what is everyone doing with the old coilovers motoman139 Titan Suspension 10 01-10-2006 02:46 PM
fox coilovers superhawk Titan Suspension 7 12-08-2005 09:35 AM
fox coilovers??? galaxycrew Titan Suspension 11 08-04-2005 01:06 AM
coilovers DaFridge Titan Suspension 4 06-20-2005 12:19 PM
