Old 07-12-2006, 01:04 PM   #1 (permalink)
sedonaguy's Avatar
Question Front Brakes Noise and Jutter on first 2-3 brakings in the morning
pretty much every morning when i leave my home for work the brakes make jutter noise like if they are wet, although it goes away after two or three applications of the brake i.e. one or to stop signs prior to leaving my neighborhood, i just wanted to know if anyone else has the problem, and/or condtion. The dealer did replace the brakes after the notorious 2004 bad brake jutter problem since then no brake jutter just early moring groans is what i call it.
sedonaguy is offline   Reply With Quote
Old 07-12-2006, 01:36 PM   #2 (permalink)
StuntDriver06's Avatar
Re: Front Brakes Noise and Jutter on first 2-3 brakings in the morning
if you live in a humid climate your rotors may be getiing surface rust overnight which wears off after the first few brake applications.... just look at the rotors through the wheel before you leave in the morning to see if they have any sign of rust on the braking surface....
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 07-13-2006, 09:35 AM   #3 (permalink)
sedonaguy's Avatar
well it is san antonio tx, but it also does it during the colder months when humidity is low...none the less thanks....
Old 07-13-2006, 09:09 PM   #4 (permalink)
My '06 was doing that and there's a TSB about that. My local dealer replaced the front pads and that took care of that. Maybe when they changed out your front brakes you got the '06 stuff put on. Check the TSB and see if it sounds familiar but mine was groaning every morning for the first 3 or 4 stops and also sometimes if I was easing off the brakes such as in a drive thru. No judder or anything just a moaning and groaning like an old woman.
Haasguy is offline   Reply With Quote
Popping noise from front end MileHighTitan Titan General Discussion 38 04-18-2007 06:53 PM
Brakes making a noise after rim replacement TitanConvert21 Titan Wheels, Tires & Brakes 15 04-05-2006 01:18 PM
Front End Noise AVI8TER Titan Suspension 7 02-17-2006 06:35 AM
Pulled over for no front plate this morning rrumaner Titan General Discussion 30 11-12-2005 10:47 PM
Clanking Noise From Front Drivers Side Brakes When Towing gravitywerx Titan Problems & Dealer Service 3 07-08-2005 09:37 AM
