Old 07-14-2006, 08:37 AM   #1 (permalink)
Trouble finding hitch for non BT Titan, help plz
Hey guys, I've got an 05 Titan no big tow. Next year I'd like to but a decent sized camper but I've been told by a hitch place and by my local nissan dealership all they can put on it is a class 3 6k rated hitch. I've seen many threads of folks w/o big tow pulling large travel trailers, boats etc. that certainly weigh more than 6k. So I assume there must be a way to get a class 4 hitch on this thing, can someone help me out and let me in on the secret. Thanks for the help.
Smoke 05 Titan LE CC 4WD
Charlemagne is offline   Reply With Quote
Old 07-14-2006, 09:32 AM   #2 (permalink)
Send a message via AIM to right_on
Re: Trouble finding hitch for non BT Titan, help plz
hey you can go to eckhardt and get a custom one for about 400 bux.
right_on is offline   Reply With Quote
Old 07-14-2006, 09:43 AM   #3 (permalink)
baseballfanz's Avatar
You can put the factory hitch on or any place like Uhual and stuff have hitch for your Titan. Even without the BT your LE can still tow 7200 lbs. Factory is your best bet cause it comes with all neccessary relays and harness. Anyone say you can't put it is full off sh*ts, my friend just got a Nissan factory hitch put on his SE CC.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 07-14-2006, 09:57 AM   #4 (permalink)
QWIKWHIP's Avatar
I also have the Nissan factory hitch on my non big tow SE. Sounds like someone is pulling your leg to me.
Old 07-14-2006, 10:02 AM   #5 (permalink)
Nissan said they would put the hitch on for me but only the class 3 rated at
6k. Is this what you're referring to as the factory hitch? I would like to have the class 4 hitch to at least max out the trucks towing capacity.
Old 07-14-2006, 10:55 AM   #6 (permalink)
QWIKWHIP's Avatar
There is only one hitch available from Nissan. It is a class IV rated hitch when used with a weight distributing hitch.
Old 07-14-2006, 11:16 AM   #7 (permalink)
CHEIF's Avatar
Get the hitch kit from Nissan. It's worth it and saves a lot of hassle. You get everything you need. Relays, 7 pin pigtail matches the wiring under your bumper, etc. Bolts right up, plugs right in and you are on your way with no headaches. I paid 240 (I think) at the dealer but you can get the same thing at yournissanparts.com for less.
You'll also have brake controller wiring near the steering column under the dash. Another plug and play. It helps you stay safe. I think at about 2,000 lbs and over it helps a lot.
At that point, the only mechanical limit is your gears, and I don't know if there are any charts or figures to help you out.
Just guessing, but I'd knock 1 0r 2k off the limit for a similar bigtow package Titan.
Qwik is right, the class 3/4 hitch is a class 3 with a standard ball, and a class 4 with the weight distribution hitch.
Happy Towing!!!!!!!!!!!
Cheif
'04 TITAN CC XE 4X4
OFFROAD PKG
PREFERRED PKG
SILVER
CHEIF is offline   Reply With Quote
Old 07-14-2006, 11:36 AM   #8 (permalink)
Who makes the OEM hitch?
3174 is offline   Reply With Quote
Old 07-14-2006, 12:14 PM   #9 (permalink)
CHEIF's Avatar
LOL you are killing me
Original
Equipment
Manufacturer
So maybe Nissan, then again Maybe not.
Sorry, I know it's probably made by a big name hitch company, but you still gave me a pretty good laugh
'04 TITAN CC XE 4X4
OFFROAD PKG
PREFERRED PKG
SILVER
Old 07-14-2006, 10:57 PM   #10 (permalink)
AF Titan's Avatar
Send a message via Yahoo to AF Titan
When you do get your hitch and you will do a lot of towing, don't forget to buy a tranmission cooler. I was looking at getting one for 60 bucks at Advanced Auto Parts. From what I'm told, very easy to install.
2005 Nissan Titan CC 4x4 SE
SE Popular Package
XM Satellite Radio
Bugdeflector
Ventvisors
Tinted Windows
AF Titan is offline   Reply With Quote
Old 07-14-2006, 11:01 PM   #11 (permalink)
SOCALTITANKC4X4LE's Avatar
AF, The Titan truck comes with tranny coolers. Even the NON BT trucks.
2005 Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b][color="Blue"]BLUE LED DASH LIGHTS MOD
1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads [b][color="Red"]487,000 miles and I'm hoping to get 500,000.
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 07-15-2006, 07:26 AM   #12 (permalink)
CHEIF's Avatar
True, like I said, mechanically, your truck will be the same as a BigTow truck except for the higher gears. They WILL reduce your capacity.
'04 TITAN CC XE 4X4
OFFROAD PKG
PREFERRED PKG
SILVER
Old 07-15-2006, 08:34 AM   #13 (permalink)
Clint's Avatar
The trans already has a cooler so adding one isn't necessary.
Clint
You have two choices in life:
Old 07-15-2006, 09:14 AM   #14 (permalink)
AF Titan's Avatar
Shows you how much I don't get to play with my Titan. Only seen it for 2 weeks, but have owned it since March. It will be December before I get to see it again.
SE Popular Package
XM Satellite Radio
Bugdeflector
Ventvisors
Tinted Windows
Old 07-15-2006, 08:58 PM   #15 (permalink)
HudsonValleyTitan's Avatar
Keep in mind also, if your truck says 6400, 7400 or 9500LB tow capacity, nothing you can add will make it legal to tow any higher than what the manufacturer rated your model. So if you ever got into any sort of trouble, be it an accident etc, and you were over the manufacurers rating for your model and equiptment, you can be held liable. But so long as you plan on being under the 7400 LB rating, you should be ok.
- Joe
Gooseneck Hitch in a Titan?? LynchTR Titan Engine, Transmission & Drivetrain 7 07-23-2007 08:00 AM
Finding out what options a Titan originally came with GKreamer Titan General Discussion 13 02-24-2006 09:00 PM
Titan Hitch Cover smhinds57 Titan General Discussion 6 07-22-2005 12:45 PM
Anyone having trouble with their Titan? UTVOL1978 Titan Problems & Dealer Service 39 01-05-2005 07:34 PM
Nissan Hitch For Titan mrcountry Titan Towing & Hauling 15 08-24-2004 09:52 PM
