Old 07-24-2006, 08:24 PM   #1 (permalink)
Lube, Oil, & Filter..."Lube" question
On the "Lube" part, is there any grease fittings on the Titan that need to be greased. Everytime I get an "invoice" it says.....
Fitting greased-0 (N/A)
Is this correct?
Thanks in advance....
brassballs1979 is offline   Reply With Quote
Old 07-24-2006, 09:05 PM   #2 (permalink)
goathead's Avatar
Re: Lube, Oil, & Filter..."Lube" question
the TITAN chassis is not one that needs lubricated. even the new cheby's have chassis grease fittings(zirts).
steve
Jiffy Lube Goofus Titan General Discussion 16 06-12-2006 04:19 PM
How do I re-lube the A-Arms? antwon412 Titan Suspension 2 06-28-2005 06:45 PM
lube capacities? Pee Wee Titan Engine, Transmission & Drivetrain 6 06-13-2005 11:24 AM
oil and lube change orvena Titan General Discussion 4 02-02-2005 09:39 AM
