I know some members on here have tried E85, but I was curious who's currently using it? I have a 2006 LE CC, and have been running it since the first tankful (about 2000 miles). Runs nice and no starting problems even though it's been 110 degrees here. Cost is only about 5% less than 87 octane, but I usually run at least midgrade so that closes the gap some. Plus Kansas is giving a $750 tax rebate for using E85, so for now I'm going to keep using it.
Non one in Austin carries it yet, so I'm not. We don't get a rebate here, so given that it's about the same price with a decrease in fuel economy, I probably won't use it. We'll see....
- Frank Zappa
I would be running, as it is usually cheaper than unleaded. But, the staion here that carries it, is out, and said the current price is $3.50 a gallon. Supply and Demand!!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
It is much less prone to detonation, but it has a much lower specific energy. Only way to get any economy out of E85 is to crank the compression ratio way up. Until we have engines with variable compression ratios, E85-capable engines will always get poor mileage burning corn...
Hemi? I've got CHUNKS of Hemi in my STOOL!
'06 Crew Cab LE in Red Alert.
Big Tow, Lorado Tonneau Cover, 6000K HIDs, Silverstar Hi's, Vent Visors, Airbox mod, Amsoil high-flow filter, billet grille.
I get about 12 MPG in a mix of highway and city driving. Not spectacular, but I don't have the lightest foot.
The owners manual suggests that you should use a "special" motor oil. I don't recall the exact wording. Anyone know any details on this? I've done google searches and haven't found any oil recommended for E85 buring vehicles.
It's been to expensive around here. What kind of mileage have you been getting over the past 2000 miles?
I only lost 1-3 mpg! Not bad when it was .30 less per gallon than reg. Unleaded.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
I woudl use it......... if I had an 05 and could find it any where.
__________________ Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Advanced Folding K-Cover ,SS Lund deflector, Black Prism DunderDan grill (I hope it's coming soon), 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (coming soon).
As Money Allows: Nismo Headers, Dynatech 2.25" Powercats (Damn Missouri and your air quality) Osirus, Trutrac, Stillen (sway bar, big brakes, diff cover), and PrerunnerTraction Bars.
Its available here but I would have to go way out of my way to get it. Have no idea what the cost is.
The manual basically says to only use 5w-30 if you run E85 (instead of being able to run 10w-30 or 10w-40 if desired). It also says to use an oil that is certified for flex fuel engines. Don't know what those are.
2006 Titan SE KC288 RWHP
2 Degree Timing Advance
Stock Airbox Mod
Magnaflow Exhaust
Tech12volt Custom box with 2 Memphis 10's
Sundown 100.2
Pheonix Gold R8.0.4
MBQuart PCE216 6.5" Comps Up front
MBQuart 6.5" Composites in the Rear
Alpine 9857 HU
I think any syn oil will do the job.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Not necessarily. The best I can tell is that FFV compativle motor oil has some kind of acid neutralizer in case the ethanol gets into the crank case. I can't find any information on the websites of the popular oils that indicate they are FFV compatible. Of course each auto manufacturer that requires special oil makes one. Ford has stopped requiring special motor oils.
I did find this which was interesting. I guess it explains why most flex fuel vehicles are trucks.
The dual-fuel loophole allows manufacturers to earn credits towards meeting federal fuel economy standards by producing vehicles that are able to run on both petroleum and an alternative fuel, even if they never actually use the alternative fuel. As a result, automakers can sell fleets of vehicles that fall short of federal fuel economy targets. In 2004, this loophole was already increasing U.S. oil dependence by 80,000 barrels per day.
Stock Airbox Mod
Magnaflow Exhaust
Sundown 100.2
Pheonix Gold R8.0.4
Alpine 9857 HU
- Frank Zappa
It is my understanding that producing the "E" part of E-85 is pretty cheap and easy. So why isn't the cost more like 15% of straight gas (I know, I know) but realistically if Ethanol is cheap/easy then I think 1/2 the price of gas is realisitic...no?
The one station that has it near me (still out of the way) has it for .05 cents less a gallon than low grade. So say on average, a 20 gallon fill up saves me ONE FREAKING DOLLAR!!
But wait, it gets better... on average E-85 gets about 3MPG LESS than straight petrol.
So instead of 14 MPG, I now get 11 MPG (But I save a buck!)
I ain't no rocket scientist but I think I see some issues...
Rod M.
'06 Silver SE CC, w/big Tow
I ran about 3 or 4 tanks of E-85. It is about 60 to 70 cents cheaper here in ND so when you calculate in the loss in mileage, it about evens out. I did notice quite a difference in mileage (decrease) but an increase in power. To me it's not only about the price and mileage, but also not having to depend on foreign countries for oil and using a product that is renewable and made in the good ole USA!!
__________________ 06 SE
Putco SSR Bedrails
Luverne Nerf Bars
Access roll-up toneau cover
18" Incubus Wheels
APC Altezza taillights
Lund SS Bug guard
PRG Leveling Kit
