TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 08-08-2006, 02:52 PM   #1 (permalink)
Wayne Kircher's Avatar
Titan Gas Assist Tail Gate Retro Fit 03/04
Ok after checking with everyone, it seams the 05 Titan gas assist Tailgate feature CAN be done with a minimum amount of sheetmetal experience and tool knowledge. It took me only about 3 hours to do and it works perfect. Just like the 05's 06's
The parts needed are...
1.93470-ZH000 HINGE ASSY-REAR RIGHT HAND...............$29.55
2.93471-ZH000 HINGE ASSY-REAR LEFT HAND.................$11.83
3.93480-ZH000 HINGE ASSY-REAR GATE RH....................$11.15
4.93481-ZH000 HINGE ASSY-REAR GATE LH....................$33.07
5.90450-ZH000 STAY ASSY - GAS CYLINDER..................$22.39
6.93334-ZH030 BRAKET T/G HINGE................................$18.04
7.90456-7Z010 STUD BALL..........................................$3.7 4
8.FLAT WASHER 1-1/2" DIAMETER X .090" THICK..........HARDWARE STORE
Tools Needed are...
1.DRILL with 1/4" bit
2.SAWALL WITH 6" METAL BLADE
3.1/14" HOLE SAW, I USED A 1-1/8" AND THEN USED A DIE GRINDER FOR A TIGHTER FIT.
4.TORX BIT FOR HINGE BRACKET COUNTERSINK SCREWS
5.3/8" AIR WRENCH AND METRIC SOCKETS TO REMOVE TAILGATE HINGE BRACKETS.
6.FILE
7.DIE GRINDER
8.TOUCH-UP PAINT AND PRIMER.
Procedure...
Please check out the pictures, they should help, I know the truck was dirty, I cleaned it up later.
First remove the tailgate, then remove the tail-light on the right rear, now on the right hinge center your drill and bit in the middle of the brackets hinge hole, drill a small amount but not all the way yet. Scribe/mark around the hinge, now remove the right hinge on the side wall and take your hole saw and finish drilling the hole, slowly so it does not chatter, it should cut easy. when you finish drilling file it so it is not sharp, test fit the New Gas hinge in the hole, file or grind to make it a snug fit, also note where the Old hinge was and try to make the new one fit exactly the same, Mine was no problem as I used a die grinder for a perfect fit. Now look down into the fender well look along the left side where you just cut the hole, follow it out and around as it makes a 90 degree turn about 1" from the screw holes, You will note the sheetmetal is too close for the new gas hinge to fit, so about 1 inch out after the 90 degree mark the top and bottom, You should see a row of spot welds runing top to bottom, you are going to cut from the top to the bottom to the right of the spot welds, this will keep the sheetmetal intact. Start your cut, then lay down and look up inside the fender well, and you can make the second cut, start about 2-1/2" back from the vertical wall and cut parallel to the bumper just to the right of the spot welds on the vertical sheetmetal, Use Eye protection here!!!! now cut the remaining piece between the vertical part the the second cut in the back, this will make the piece on the right loose, Use a plier/vise grip/adjustable wrench and slowly bend the loose right piece 90 degrees toward the front of the truck. Now you can see you have the clearance for the Gas shock and hinge assy. Next take the New two piece hinge assy and seperate them you will only need the smaller part. as in the pictures cut with your sawsall along the right side to trim it to fit into the 90 degree cavity so the the holes line up. Mount the Gas Hinge for the right side to the part you just cut, (file to fit perfectly), attach the Gas cylinder to the bottom hinge stud, hold it square and down until it stops,then mark the center of the top mount location, drill and mount the top stud ball with the large washer in the back (you need another person for this to hold the stud). Now remove both hinges off the tail gate and mount the new ones on use blue locktite, remove the left fender wall hinge bracket and mount the new left one (Here Nissan reversed the obround hignes so you can remove/replace the tailgate) Replace the tailgate and test, It should move down slightly after opening then stay with one finger you can lower or raise the gate, close it and check for fitment. Now you can disassemble and prime/paint and replace. Good Luck.
titan-gas-assist-tail-gate-retro-fit-03-04-img_0594.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0595.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0610.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0611.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0612.jpg
2004 LE 4X4 CC
Off Road Package
J&J z grill front end
2" lift Kit
Front 2" hitch mount for winch
Back up rear camera
Nissan Gas Assist Tailgate retro-fit
Born 06/30/2004
Purchased 10/30/2004
1200 miles changed to Synthetic oil "Mobil 1" in Engine
2500 miles changed to Synthetic oil in Rear end.
Wayne Kircher is offline   Reply With Quote
Advertisement
Old 08-08-2006, 02:54 PM   #2 (permalink)
Re: Titan Gas Assist Tail Gate Retro Fit 03/04
More pictures.....
titan-gas-assist-tail-gate-retro-fit-03-04-img_0614.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0622.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0615.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0600.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0616.jpg
2004 LE 4X4 CC
Off Road Package
2" lift Kit
Back up rear camera
Born 06/30/2004
Old 08-08-2006, 02:55 PM   #3 (permalink)
Canusaytitan's Avatar
I have an 04 with tailgate assist?? Bought new.
Canusaytitan is offline   Reply With Quote
Old 08-08-2006, 02:57 PM   #4 (permalink)
Still more pictures.....
titan-gas-assist-tail-gate-retro-fit-03-04-img_0617.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0619.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0621.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0623.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0626.jpg
2004 LE 4X4 CC
Off Road Package
2" lift Kit
Back up rear camera
Born 06/30/2004
Old 08-08-2006, 02:58 PM   #5 (permalink)
Last four pictures....
titan-gas-assist-tail-gate-retro-fit-03-04-img_0627.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0628.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0629.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0630.jpg
2004 LE 4X4 CC
Off Road Package
2" lift Kit
Back up rear camera
Born 06/30/2004
Old 08-08-2006, 02:59 PM   #6 (permalink)
Sammy Sandbag's Avatar
Then someone added it aftermarket. You sure it isn't a torque rod rather than the actual pneumatic lift?
Wayne, awesome job. I've been waiting for someone to tackle this one.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 08-08-2006, 03:03 PM   #7 (permalink)
I bought it with 7 miles on it. I can pull the handle and the tailgate will slowly drop down to the bottom. It is not aftermarket.
Old 08-08-2006, 03:04 PM   #8 (permalink)
Well I don't know what to say, other than you got a freak truck on your hands. Consider yourself lucky. Was it a late model '04, possibly an '05?
-Counsel Yourself
Old 08-08-2006, 03:05 PM   #9 (permalink)
I purchased in December of 04. Maybe they started putting them on a little early. I dont know but I do have it.
Old 08-08-2006, 03:05 PM   #10 (permalink)
Yes! but not many 03's/04's had the assist added. heres a few more pictures...
titan-gas-assist-tail-gate-retro-fit-03-04-img_0598.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0599.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0601.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0602.jpg  titan-gas-assist-tail-gate-retro-fit-03-04-img_0604.jpg
2004 LE 4X4 CC
Off Road Package
2" lift Kit
Back up rear camera
Born 06/30/2004
Old 08-08-2006, 03:07 PM   #11 (permalink)
I doubt many '03 Titan's had the assist.... or tailgates for that matter.
Again, nice work. I might have found a new project to do.
-Counsel Yourself
Old 08-08-2006, 03:08 PM   #12 (permalink)
Thanks Sammy, I figured I would try first before posting, and it works like a charm, I may add a small bracket between the sheetmetal that was cut so it will not vibrate, so far no problems.
2004 LE 4X4 CC
Off Road Package
2" lift Kit
Back up rear camera
Born 06/30/2004
Old 08-08-2006, 03:56 PM   #13 (permalink)
pi3yeargrad's Avatar
nice nice...I would like to have this but I remember another option besides the tortion bar that looked like it worked real good and was in the planning of making for the titan....well see...
what will happen if u just open the tailgate and then let it drop? will it just fall (regular) hard or will it slowly fall?
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 08-08-2006, 05:34 PM   #14 (permalink)
Rider's Avatar
The wife drop the tailgate on my titan and.... SH1T!!!!!!!!!
2004 RED BRAWN LE, KC, 4x4, Big Tow, Utili-Track, Pioneer AVIC-N2, Directed Video Multimedia Unit, Nitro 8" Headrest Monitors, Clifford Matrix 10.5X 2-Way Alarm with Remote Start, Back-Up Camera, O.E.M. Underseat Storage, "TITAN" Decal, A.R.E. LSII Fiberglass Tonneau, AMI 6" Billet Antenna, GrillCraft BG Series 4-Piece Billet Grille, O.E.M. Hood Protector, O.E.M. Bed Extender, Custom Dual Exhaust, "TITAN" Hitch Cover
Coming Soon: PRG 4" Performance Lift, RadFlo 2.0 Rear Shocks, Total Chaos Rear Shackles, Parrot 3200 LS, "TITAN" SS Door Sills, Chrome Tailgate Trim, Chrome Taillight Trim, Chrome Bug Shield, 4x4 Emblems, Fender Flares, Red Brawn PC'd Steps
Sig. Pic. Made by CLi006
Rider is offline   Reply With Quote
Old 08-08-2006, 06:08 PM   #15 (permalink)
Aquaholic's Avatar
Nice to know it can be done. I wish they had done that the pig tail for the break controler and the power rear window in 04.
2007 White with Charcoal/Titanium interior SE CC 4x4 with off road, tow, SE popular with bench, and utility bed package with sliding bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, SAW Racerunner bracket lifted 2.5" coilovers w/Eibach springs, PRGproducts UCAs, Rear SAW Racerunner 2.25" shocks, 325/65/18 Kuhmo Road Venture All terrains, 18x9 Moto Metal 954s, Stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, Rubber bed mat, 2008.5 Chrome grille, K&N 6012 , Custom FlowMaster DeltaFlow 50 series dual in single out muffler, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Infinity Reference 6 1/2's in rear and 6x9's in front, Infinity 1600a mono amp, (2) 1060W Infinity Reference subs, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH
Aquaholic is offline   Reply With Quote
tail gate assist titancst Titan FAQ & Howto Area 4 08-11-2006 08:43 PM
tail gate gap helomech Titan General Discussion 4 11-15-2005 10:59 AM
Chrome Tail Gate and Tail light bezels DWBTITAN421 Titan Parts & Accessories 1 08-28-2005 12:06 PM
Titan without the tail gate? Thundertank Titan General Discussion 23 04-20-2005 04:51 AM
Tail Gate gsxr1000 Titan General Discussion 0 02-05-2004 06:36 PM
