Old 08-26-2006, 12:03 AM   #16 (permalink)
vegashd's Avatar
Re: p$nis envy
Originally Posted by DRTYAZN
Definitely not a U-turn friendly vehicle, as most of the big3's... Even with lifted and 35's, I crank a single turn U-turn all the time while the chevies, ferds, and doggs have to 3 point them. Not to mention, the suspension and ride is fabulous in our Titan's unlike the $$$ you have to spend to get their's to be smooth like ours... my pocket feels better then his too...lol!
I am not so sure you have checked out the 05 and newer SDs. I am pretty sure with a 10" lift and 38s they make a tighter 90* turn then a stock titan. I would love ot know the turning radious of each.
vegashd is offline   Reply With Quote
Old 08-26-2006, 12:32 AM   #17 (permalink)
Aquaholic's Avatar
Re: p$nis envy
Don't let it make you feel low. When he breaks down you can give him a tow back to his house.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 08-26-2006, 03:34 PM   #18 (permalink)
vegashd's Avatar
Re: p$nis envy
Old 08-26-2006, 03:43 PM   #19 (permalink)
Re: p$nis envy
He's a bounty hunter too....i think.
A: he is screwed if he needs to be sneeky
B: If you see your target and he goes buy you, a 3 point turn should be Awesome
C: F it and just drive the truck onto his
SoCalCheez is offline   Reply With Quote
Old 08-26-2006, 03:54 PM   #20 (permalink)
chunko's Avatar
Re: p$nis envy
Game set match
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 08-26-2006, 03:57 PM   #21 (permalink)
chunko's Avatar
Re: p$nis envy
On a side note...
Is it just me or to you need a few shots a JD before the JD girls look hot...smart thinkin JD..smart thinkin...
2005 CC 4x4 SE
AKA
Old 08-26-2006, 05:38 PM   #22 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Re: p$nis envy
Originally Posted by adavis99
Game set match
hey isnt that shaqs ride?
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*AT3030XL muffler / 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is offline   Reply With Quote
Old 08-26-2006, 06:03 PM   #23 (permalink)
Carbeaux's Avatar
Re: p$nis envy
I don't have any idea what practical use those big 'ol honkin' things would have, and despite the fact they are Fords, I like them both. Wonder what the towing capacity on them are?
Hook 'Em Horns!
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand that...
Old 08-26-2006, 06:06 PM   #24 (permalink)
chunko's Avatar
Re: p$nis envy
Well done sir...yes it is.
2005 CC 4x4 SE
AKA
Old 08-26-2006, 06:07 PM   #25 (permalink)
chunko's Avatar
Re: p$nis envy
Towing specs...googlewhore to the rescue.
2005 CC 4x4 SE
AKA
Old 08-26-2006, 06:08 PM   #26 (permalink)
chunko's Avatar
Re: p$nis envy
Road Test: Overbilt F-650 Extended Crew Cab Overbilt F-650 Extended Crew Cab
General
Location of final assembly Lebec, California
Body style Six-door truck
EPA size class Class 6 medium duty
Drivetrain layout Front engine, RWD
Airbags None
Powertrain
Engine type Turbodiesel I-6, iron block/head
Bore x stroke, in 4.33 x 5.00
Displacement, ci/L 442/7.2
Compression ratio 16.5:1
Valve gear OHV, 3 valves/cyl
SAE horsepower, hp @ rpm 300 @ 2400
SAE torque, lb-ft @ rpm 800 @ 1440
Transmission type Allison MD-3066 6-speed auto
1st 3.49:1
2nd 1.66:1
3rd 1.41:1
4th 1.00:1
5th 0.75:1
6th 0.65:1
Reverse 5.03:1
Axle ratio 4.88:1
Recommended fuel Diesel #2
Dimensions/Capacities
Wheelbase, in 194.0 (from factory)
Length, in 281.0
Width, in 97.0
Height, in 88.3
Headroom, f/r, in 41.5/41.0
Legroom, f/r, in 41.2/42.8
Shoulder room, f/r, in 68.0/66.9
Hip room, f/r, in 67.4/67.3
Ground clearance, in 10.0 (at front axle)
Base curb weight, lb 9000 (est)
Payload capacity, lb 30,000 (est)
GVWR, lb 25,999 (est)
GCWR, lb 70,000 (est)
Towing capacity, lb 18,500
Fuel capacity, gal 100.0 (dual 50-gal tanks)
Chassis
Suspension, f/r Beam axle, leaf springs/live axle, air suspension
Steering type Power recirculating ball
Brakes, f/r Hydraulic disc/hydraulic disc, ABS
Wheels 22.5 x 8.5 Alcoa
Tires Goodyear 10R22.5
Performance
Acceleration, sec 0-60 21.3 1/4 mile, sec @ mph 21.9 @ 60.5
Braking, 60-0, ft 170
Fuel economy, city/hwy 9/12 (est)
Price
Crew-cab model $82,000-$85,000 (est)
Six-door model (as tested) $115,000 (est)
Four-wheel-drive option $10,000 (est)
2005 CC 4x4 SE
AKA
Old 08-26-2006, 06:09 PM   #27 (permalink)
chunko's Avatar
Re: p$nis envy
18,650....well nice to see you could pull an F350 pulling a titan pulling a 9000lb boat with plenty of weight to spare.
2005 CC 4x4 SE
AKA
Old 08-26-2006, 06:13 PM   #28 (permalink)
Carbeaux's Avatar
Re: p$nis envy
^^^^LMAO Thanks GoogleMan! Those acceleration times slay me, but then again, it probably wouldn't be much different for that rig pulling all the above either.
Hook 'Em Horns!
Old 08-26-2006, 06:19 PM   #29 (permalink)
chunko's Avatar
Re: p$nis envy
I wouldn't feel safe in it...no air bags
2005 CC 4x4 SE
AKA
Old 08-26-2006, 06:27 PM   #30 (permalink)
BKW
Re: p$nis envy
This beast has less front legroom than a Titan?
And who is the heck is building trucks in Lebec, a wide spot off Highway 99?
BKW is offline   Reply With Quote
Titan Envy itscookeyo Titan General Discussion 11 01-29-2005 11:28 PM
