My recently purchased used '04 Titan CC has about 3 months remaining on the factory warranty but only has 22,000 miles on it. I am concerned about brake judder but at this point I don't feel that the brakes have any problems. Is there any way to tell if these are the original rotors and pads? Are the "final fix" rotors the same size as the originals? I am going to take it into the dealer to have a couple of items fixed and was wondering if I should just tell them that I have judder and see if they will do anything about it. Thanks for any adivce or opinions.
OC, i just went in and told my serv. man. that the steering wheel has started shaking when the brakes were used..He said judder right away and told me it was covered to have 4-rotors and new pads installed FREEEEEEE!!! .
i have the extended warranty to 75K w/50$ deduct. He said it was covered through nissan, so i shut up. My truck has 52K, its an `04...Each stealership is different.. Good luck
When the service tech runs your vin, the service records should show him if the fix was done, also any of the tsb or recalls.
2008 SE CC 4X4 RED BRAWN w/popular package, Big tow, Bed utility w/bed extender, Fog lights and back up sensors, Homelink
MODS:
Sirius
TomTom GPS
DIY Intake Mod w/K&N drop in
Activetune Grounding Kit Red wires
Magnaflow Cat-Back
Silverstars
Luminics Pure Blue 6000k fog lights bulbs
Nissan Steprails
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Armada Airdam mod
I did all this without wife knowing
Also, nissan has extended the warrantee on the brakes on the titans.... If you are in cali, take it to performance nissan in duarte and talk to Tim. He will hook you up.
A quick way is to look at the rotors, if there's a groove near the center hub it's the newer style, the older style is flat all the way to the center hub. You can still get the judder with the newer style rotors if you still have older style pads.
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
I was talking to my frend who works at a nissan dealer yesterday and he said the rotors and calipers on the 07s are huge in comparison to the current brakes including the current permanent fix.
..i just went in and told my serv. man. that the steering wheel has started shaking when the brakes were used..He said judder right away and told me it was covered to have 4-rotors and new pads installed FREEEEEEE!!!
I did the same with the dealership in Salisbury, NC., but in my case I really hadn't experienced any brake problems, I just wanted to make sure I got the "fix" before my warranty ran out and then I was stuck. The service man didn't blink, and completely replaced my rotors and pads for free. Heck, they even washed my truck when I went in to pick it up. I'm happy.
2004 Nissan Titan Crew Cab SE 4WD
Pearl White Ext - Black/graphite Int
Popular Pkg. w/Captains Chairs
Off-Road Package
Big Tow Package w/e-locker
Utility Bed Package
Born May 2004
Options: Weathertech Floor Liners and Window Deflectors. DU-HA Underseat Storage. Wet Okole Neoprene Seat Covers. Active Tuning. '06 Differential Cover Mod. Brake Fix. A.R.E. Z Series Camper Top. More to come!
