Old 09-01-2006, 08:02 AM   #1 (permalink)
rww22's Avatar
TPMS Question
I did some searching to see what I could find. Not a lot of help, so here's my question.
Yesterday my tire pressure monitoring system decided to tell me that I have a tire pressure problem. The light came on but all of my tires are fine. The light has been on ever since.
Do these tire pressure monitors go bad? The light on the dash is not doubt annoying and I would like to get it fixed...
'04 Titan SE Crew Cab
4X4, Off-Road, Big Tow
Pop Capt., Nitto 295/75/17
rww22 is offline   Reply With Quote
Old 09-01-2006, 09:13 AM   #2 (permalink)
Nissan Mike's Avatar
Re: TPMS Question
Check your tire pressures with a known good gauge.A variance of about I think 5 psi is all it would take to trip this light,set all pressures equal and drive about 2 miles.If light stays on you probably have a bad sensor
TPMS Compatibility Gunner22 Titan Wheels, Tires & Brakes 9 05-12-2006 07:46 AM
Can I get the TPMS to work on a base XE? miketan Titan General Discussion 3 10-10-2005 04:44 AM
Permanent brake fix question, rotor question. SWTXTITAN Titan General Discussion 4 08-06-2005 05:44 AM
Question about TPMS and buying aftermarket Rims. TENNESSEETITAN Titan Wheels, Tires & Brakes 2 06-30-2004 09:12 PM
