Old 09-11-2006, 08:56 AM   #1 (permalink)
VDC Slip OFF problem
New to the site here. Just wondering if anyone has had this same problem. I was driving along about 60 and lost power. the truck was still running but had the vdc slip light was on. was able to limp home at about 15-20 mph under its own pull. The engine would not rev when giving it gas. About an hour and a half later it ran fine but with the check engine light on. Has anyone else had this happen, if so what was the outcome? My truck has about 19k miles on it. Any comments are appreciated. Thanks.
Elliot1000rr is offline   Reply With Quote
Old 09-11-2006, 09:33 AM   #2 (permalink)
tnbowhunter's Avatar
Re: VDC Slip OFF problem
It sounds like it went into what is called "safe mode."
Mine did the same thing a year ago, I have no clue as to why it happened but it did.
It has not done it since.
I will try to find the thread when my truck did it.
Did the check engine light go off after you restarted the truck?
2001 Polaris Sportsman 500.
Old 09-11-2006, 09:38 AM   #3 (permalink)
Here ya go...................
Help!!!!!
Old 09-11-2006, 09:47 AM   #4 (permalink)
the check engine light is still on. this happened yesterday(sep. 10th). thanks for the info.
Old 09-11-2006, 11:34 AM   #5 (permalink)
Supporting Vendor
P's Titan's Avatar
Something similar happend to my truck right after I bought it, it ended up being the valve body sensor I think. I have seen some similar stuff on here but no one has come back to say if that was it.
My problem sounded like what your going through, would give gas but would not go. The Check Engine light would stay on and never go off. If you take it in and they can't figure it out, have them call Power Nissan in Torrance and ask for the Service Manager. He spent a week trying to figure out what was wrong.
my mods list
USE DISCOUNT CODE FOLGER FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 09-11-2006, 12:31 PM   #6 (permalink)
I'm taking it in wed morning. I'll let you know what they say. thanks for all the info.
Old 09-11-2006, 06:27 PM   #7 (permalink)
Thumbs up Re: VDC Slip OFF problem
Same thing happended to mine at around 40,000.
took it off cruise control, coasted to a turn and couldnt accelerate and went to my fire station down the street and sat for about an hour and as if by magic the power returned but with the afore mentioned lights on. the Nissan service rep said it was my onboard computer and not to use cruise control until it could be replaced.
no problems since it been replaced, 27,000 mi ago...
matt
Cptnmatt is offline   Reply With Quote
Old 09-13-2006, 09:09 PM   #8 (permalink)
Supporting Vendor
P's Titan's Avatar
Elliot.. what if anything have you found out ?
my mods list
CrankyWhore™
TequilaWhore™
Old 11-12-2006, 08:06 PM   #9 (permalink)
I know this post has been quiet since September but I just had the same problem last week in Southern California and since I’m from Northern California, this was a problem. Their service rep. told me it was a bad ECM so my truck has now been at Empire Nissan in Ontario for over a week waiting for parts while I wait at the other end of the state. I’ll let everyone know if the fix works or if something else fails once the new ECM is installed.
j-jr is offline   Reply With Quote
"SLIP" Light Problem Dealers says needs to replace entire wire harness unit!!!!!!!!!! panamajack79 Titan Problems & Dealer Service 3 08-08-2006 10:47 PM
Problem: weird slip when pulling out BIGT56PA Titan Problems & Dealer Service 33 06-01-2006 04:21 PM
Problem with Brake/VDC/Slip Lights canman Titan Problems & Dealer Service 9 02-15-2006 10:22 AM
VDC / Slip 305hp Titan General Discussion 19 01-08-2005 11:14 AM
Yet Another Problem......"VDC OFF" "SLIP" Lights gedunk Titan General Discussion 2 09-17-2004 09:30 PM
