Old 09-13-2006, 06:16 AM   #1 (permalink)
Blacked Out Headlight Mod Questions???
I performed the blacked out headlight mod 2 weeks ago and love the new look. However, we got a good rain yesterday, and there is quite a bit of moisture inside the light??? When I reassembled the lights they went back together very tight, I even applied a bead of silicone caulk around the outside edge.
I did this same mod to my previous truck, '03 Frontier, and had no problems. I did notice that the Frontier's headlights were vented, and the Titan's were not, at least that I could tell. In the Titan Headlight TSB, (the one about moisture in the headlights) it says that the headlights are vented for air to expand and contract during weather changes. Is it possible that I sealed the headlight too well???
TitanJim is offline   Reply With Quote
Old 09-13-2006, 07:09 AM   #2 (permalink)
QWIKWHIP's Avatar
Re: Blacked Out Headlight Mod Questions???
I've had mine done for a couple months now and have not had an issue at all. When I reassembled mine I put a fresh bead of black RTV sealant in the groove before I put them back together. I'm thinking that maybe by you applying the sealant afterwards that it didn't seal as well as it should have. That's the only thing I can think of???
Old 09-14-2006, 06:17 PM   #3 (permalink)
I totally agree with QWIK......
Best bet would be to take them back off, re-split them, and reseal them with the Black RTV Sealant.
titanse05 is offline   Reply With Quote
Old 09-14-2006, 06:27 PM   #4 (permalink)
Mr. B's Avatar
I have no opinion on the cause, but I will tell you that in 1989 I bought an F-150 that had those big frog eye lookin' headlights....after about a year, I developed alot of moisture inside one of them so I took it to the dealership and showed the service writer....he pulled out a 1/4 inch drill, laid down on his back and drilled a small hole in the bottoms of both headlight assemblys....straight up from behind the bumper.....I never ever had any more moisture issues again....I sold the truck in 1997 with 165k miles.....I suppose what he did was open up a vent hole to allow any condesation or moisture to evaporate out.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 09-14-2006, 06:36 PM   #5 (permalink)
jdavisjr8's Avatar
I also experienced this problem after the mod. I drilled 4 small holes in the bottom of each assembly and haven't had the problem since...
05 SE CC SE 4X4, utility pack, big tow,w/captain seats and Rockford Fosgate : GOODIES INCLUDE: Stillen leveling kit, K&N filter "looking at adding FRAMBOOST system", Flomaster Series40 Duals w/side exits, Nissan hood protector, Ventshade window visors, Aries step rails, Nissan fog lights w/new separate wiring harness and switch, Nissan allseason mats, KUMHO VENTURE A/T 325/60R18, clear bra, blacked out headlights
jdavisjr8 is offline   Reply With Quote
Old 09-15-2006, 07:25 AM   #6 (permalink)
I will try drilling holes in the headlight assembly.
Thanks for the input guys.
Old 09-29-2006, 06:00 AM   #7 (permalink)
Update...
I drilled 2 small holes on the underside of the headlights last weekend and have had no problems since. Thanks everyone for the input!
Old 09-29-2006, 06:29 AM   #8 (permalink)
mopar's Avatar
Send a message via AIM to mopar
Yep now the moisture has an escape route to evaporate out. I think they make them airtight to keep the connector and light assembly corroding and to prevent premature bulb failure. I'd wonder about in the winter but it sounds like you got it fixed you may have to replace the bulbs more often maybe try some dielectric contact grease in the socket to prevent any corrosion or oxidation from the moisture.
Sean
RLTW
05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG 4" Perfomance lift--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
mopar is offline   Reply With Quote
Blacked out Tail Brake Lights TitanHigh Titan General Discussion 58 01-11-2007 12:57 PM
Blacked out headlight mod with HID's g356gear Titan Parts & Accessories 1 04-30-2006 06:55 PM
Pics of Blacked Out Corners and Red Brake Calipers 1BadTitan Titan Pictures & Media Post 15 04-08-2006 04:53 PM
More Headlight Questions MSnook Titan General Discussion 4 06-13-2005 02:46 AM
Blacked out Burger raxton Titan Pictures & Media Post 13 04-20-2005 09:54 AM
