My odometers on my 04 are now way underreporting mileage. I use the B for oil changes and its now not reliable. Anyone else have this problem. I did a search but didn't see a title that was relevant.
WOW...Man I might have better MPG. I wish, I think mine is right. Same distance to work with a couple of other vehicles...I have never heard of this problem on this site.
old ride - 04 XE CC 4x4 traded at 62k
thanks
My odometer is off around 4% (on a 10 km measured distance, my odometer shows 9.6 km).
Question for you - what do you mean when you state - "I use the B for oil changes" ???
2004 Titan King Cab SE 2WD Deep Water
Leer Truck Cap, Running Boards, Fog Lights, Hood Protector, Tow Package, Versatility Package, "TRUE" dual exhaust system (2.25" exhaust piping) with Magnaflow XL mufflers and Magnaflow SS tips (2.25" in and 3.00" out) Goodyear Wrangler Silent Armor tires
Most odometers and Speedometers are off slightly on vehicles. Anywhere from 1-6% . Varies by year/manufacturer/mech/digital, and many other factors. From what I have seen most are off about 3-4% at 60 mph.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
On a recent trip to Colorado I took my brothers GPS device with me. Speed wise if I was travelling 70 by the speedo in the truck, the GPS registered 67. However, the milage on the odometer and the milage over the trip with the GPS were the same I really do not know how to explain that one, even a 1% change from the GPS should have shown up over the 3,000+ miles we travelled.
2005 Titan Crew Cab
Mods: Flowmaster 40 Series, K&N Drop In Filter, Cool Nismo Sticker
My speedometer reads about 3-4 mph high at 70, and my odometer will register 104 miles on a 100 mile trip. A & B do the same thing.
Mine reads 95 miles for a 100 mile trip. But I do not have big tow.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Speedometers are calibrated at the factory based on a SINGLE tire size for each model. If the truck can be configured with three different tire sizes, they will calibrate for the "middle" tire size. I got this information from a Toyota dealer when I had my Tundra with off-road tires, FWIW.
'04 Titan Galaxy LE KC 4x4
Off Road & Big Tow Packages
Build Date: 06/14/04
Buy Date: 06/25/04
Wade In-channel Vent Visors
PRG's Front Leveling Kit
P/A 3" Body Lift Kit
Bushwacker Fender Flares
Billet Grille
MagnaFlow Single Side Exit
Nitto Dune Grappler A/T (315/70/17)
Firestone RideRite Airbags
If the odometer under-reads the mileage, then that means you get more than 36,000 miles before your truck actually hits the warranty.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
I zero out the B odometer when I change the oil. Its more than 4%, could be as much as 50-60%. Way off. I am in the process of checking the main odometer against the accessory ones and will report the exact figure.
Are you sure that you just didn't reset it on accident?
I am pretty sure its untouched. You have to hold it in for a long time for anything bad to happen. What did I just say???? Anyway since I got the GArmin 276 which by the way is a pip, I use the trip computer on the GPS for all the odometer chores and can now dedicate the onboard ones to shtuff like oil changes.
