Old 09-20-2006, 07:37 PM   #1 (permalink)
Treebasher's Avatar
Tire sensor issue with chromed caps
I just got a set of Nitto Terra Grapplers today and like them a lot, so far. When the guy at the shop went to remove the caps on valve stems they were seized. I lost a couple of the stock stem caps and had replaced the stock stem caps with a cheap set of chromed caps. The guy was able to get off three of the caps but broke one of the valve stems taking off the fourth. Their explanation was that the chromed caps carrode quicker with air/moisture with the nickle stems on the sensors??? I have no idea if this is the real reason or not but the metal caps on metal stems were no good.
He called right after it happened and said they broke one and that would be another $50 for a new sensor(luckily in stock). After a breif discussion about who broke what, we met in the middle and I paid $25. I figure this was 1/2 my fault.
He also said that all cars will have pressure sensors in a couple of years(gov. regs). They have specific grey, plastic caps with a rubber O-ring on the tip, that they use. He was suprised the dealer didn't say something about the caps during oil changes. Which makes wonder how they were able to check the tire air pressure they said they checked. That's the last time I trust anyone working on the truck.
I just thought I'd share. I snapped a couple of crappy pictures to show the corrosion on the broken stem.
tire-sensor-issue-chromed-caps-stem1.jpg  tire-sensor-issue-chromed-caps-stem2.jpg  tire-sensor-issue-chromed-caps-stem3.jpg
Born on 01/2004
K&N Filter Charger and prefilter...........Stubby antenna
Westin Bull bar.........................................Front tint
PRG leveling kit........................dss90c LED bed lights
Access tonneau cover.................Stainless bug guard
GT seat covers.........................Tailgate assist spring
Husky floor mats.............Tailgate key fob locking mod
Banks "Monster" exhaust.......................Keyless entry
AT grounding kit................................HID headlights
Grille inserts.....................295/70 R17 Nitto Grapplers
Alum. rear diff. cover...........................HID fog lights
next?
Treebasher is offline   Reply With Quote
Old 09-20-2006, 07:48 PM   #2 (permalink)
rynomx785's Avatar
Re: Tire sensor issue with chromed caps
I worked at a tire shop for almost 2 years. They dont corrode the idiot taking off the tire forgets that it is there and brakes it with the tire machine. It happened fairly often at the shop I worked at but we payed for them not the customer.
Old 09-20-2006, 08:15 PM   #3 (permalink)
Treebasher's Avatar
I'm thinking I'm going to take the sensor back to the dealer. I just had the truck in for an oil change yesterday. They fill out a checklist sheet that shows the tire pressure for each tire! Someone is lying... Either the dealer is not checking the tire pressure during the oil changes or the grease monkeys at the tire shop are idiots and broke the stem. However, I have the stem in hand and I can see quite a bit of crap in the threads. I'm leaning toward a problem with cheap chromed caps.
Born on 01/2004
next?
Old 09-20-2006, 08:42 PM   #4 (permalink)
TitanBlue's Avatar
Treebasher,
I just mailordered rims and had installed at local shop. They showed and warned me of danger of breaking sensors, esp. since angle changed on new rims vs oem steel. That is first issue.
Second issue now: At our Charm City Titan meet last week, I was showing/discussing the solid brass body of my "8 Ball" valve caps vs myoldblue anodized caps that had traditional black nylon caps inserted in them. (One of them lost grip to the aluminum and I had to use pliers and pull it off the stem). Buddy related he had chrome metal caps like you had, and they corroded onto the stem. He now puts a little grease on the chrome ones.
So dealer "may" have broken it getting cap off, not tire from rim. $50 good price, as dealer is $115. $25 good compromise.
Yeah, they always check it off the list, just don't always check it. Buy a gauge and check em yourself, at least once a month.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 09-20-2006, 10:02 PM   #5 (permalink)
Treebasher's Avatar
Originally Posted by TitanBlue
Treebasher,
I have no excuse for not checking the tire air pressure on my own. The more I look at the broken valve stem the more I think there was an interesting chemical reaction going on. I've learned my lesson.
Born on 01/2004
next?
Old 09-20-2006, 10:21 PM   #6 (permalink)
baseballfanz's Avatar
I have heard of others with problems by putting on different stem caps. They seize and was stuck on the stem valves.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 09-20-2006, 11:00 PM   #7 (permalink)
TitanGixx's Avatar
enjoy those Nitto's! mine are AWESOME!
04 SE CC, Smoke
Billet Grille, Nitto Tera Grapplers, PRG 1" Mini Lift, K&N Filter, 5% tint, MagnaFlow Exahust
04 Suzuki GSX-R 600 Blue/White
tons of Carbon Fiber goodies
TitanGixx is offline   Reply With Quote
Old 09-21-2006, 08:24 AM   #8 (permalink)
Treebasher's Avatar
I can tell a big difference with the Nitto's. My stock rugged trails were done. The truck runs a lot smoother now. I'm headed to Canada in a couple of days for a week of hunting. That'll be a good test for them.
Born on 01/2004
next?
Tire pressure sensor gotjumps Titan General Discussion 10 07-19-2008 12:02 PM
FYI...Tire sensor leaks SOCALTITANKC4X4LE Titan Wheels, Tires & Brakes 5 09-08-2006 01:32 AM
Tire sensor myths Yomama Titan General Discussion 13 04-13-2006 06:59 AM
Tire pressure sensor..??? SLOW_V Titan Problems & Dealer Service 17 12-16-2005 01:22 PM
Tire pressure sensor engine17 Titan Wheels, Tires & Brakes 3 07-28-2005 12:40 PM
