Old 09-28-2006, 12:56 PM   #16 (permalink)
Yellomantis's Avatar
Re: Removing the Sway Bars and Flipping the Coil Bucket for an Added 1"??
How are you going to flip the coil bucket?!?!?!? IT'S WELDED IN PLACE!!! Something must have been lost in translation....
www.myspace.com/yellomantis
Old 09-28-2006, 04:19 PM   #17 (permalink)
MississippiTitan's Avatar
Send a message via AIM to MississippiTitan
maybe greg would let us know. I cant ever get a hold of him to ask. so maybe somebody else will have better luck.
MississippiTitan is offline   Reply With Quote
Old 09-28-2006, 10:37 PM   #18 (permalink)
justrich's Avatar
i was warned by greg about maxing out the coilover. i forgot what he warned me about. has anyone had problems with there performance kit maxed out. im also curious about this flipping of the coil bucket im curuious to see results.
justrich is offline   Reply With Quote
Old 09-28-2006, 10:40 PM   #19 (permalink)
kartman's Avatar
I ran my DRs maxed for awhile. It does not ride great in comparison to having the preload centered as you have almost no droop.
Rebar Wrangler
Old 09-30-2006, 09:41 PM   #20 (permalink)
No joke! Someone definitely misunderstood something.
And yes, maxing out the coilover will make for quite a harsh ride but if you just want the look it'll work!
lifeinthesouth is offline   Reply With Quote
Old 09-30-2006, 09:54 PM   #21 (permalink)
Blindside1234's Avatar
ok, taking out a sway bar is not good, espically in vehicles with a high center of gravity. It also helps the lower control arm to maintain its position in turns and prevents body roll. A sway bar is also refered to as a stabalizer bar, and for good reason, also adding an inch will make the tie rods higher than the steering knuckle thus giving you lots of alignment problems, positive camber and TREMENDOUS amounts of bumpsteer will occur.
Originally Posted by Toomnymods
nevermind blindside he's the village idiot that bashes everyones posts here at TT
Blindside1234 is offline   Reply With Quote
Old 09-30-2006, 10:47 PM   #22 (permalink)
Man, you got that right. I see so many lifted trucks around here with the front wheels leaning in towards the top. Especially when you see them driving down the freeway or something. Not only are the front wheels at such a positive camber, but the wheels are usually toe'd out to a ridiculous amount as well.
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
Old 09-30-2006, 10:50 PM   #23 (permalink)
kartman's Avatar
Someone forgot to tell my truck it has bumpsteer. You are full of bad info today. Thanks.
Miketitan, positive camber is top of the wheels out not in.
Rebar Wrangler
Old 09-30-2006, 11:30 PM   #24 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
i'm running the CST kit and Radflo coilovers up front, so i'm sitting around 9-10 inches higher than stock. Yes, there is more bodyroll going into corners, but I don't have any problems taking turns. When Greg removed my bar, I asked him that exact same question. He told me that the sway bar doesn't allow the full potential of the coilovers. By removing the bar, you force the coilovers to work. Keeping it in place along with the coilovers more or less keeps the truck going straight. Yeah, I know i'm not too clear, Greg or Kartman could probably explain it WAY better than I can. But in my opinion, I haven't noticed a difference big enough to warrant replacing the sway bar.
No more sig for me
i<3mytitan is offline   Reply With Quote
Old 10-02-2006, 01:38 PM   #25 (permalink)
justrich's Avatar
would removing the sway bar on my performance kit improve performance? if it doesnt perform better then im not interested.
Old 10-02-2006, 03:55 PM   #26 (permalink)
kartman's Avatar
That depends on your perceptions and wants. I liked it better. It takes about 3 minutes to try out. Remove one swaybar endlink fron the truck and drive it around for a couple days. If will feel wierd at first so give it a fair shot. If you dont like it reinstall the endlink, if you like it remove the bar and other endlink
Rebar Wrangler
Old 10-02-2006, 08:49 PM   #27 (permalink)
loufish's Avatar
I'm still waiting for an explanation of this "bucket flipping"...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 10-02-2006, 08:51 PM   #28 (permalink)
kartman's Avatar
He got the terminology wrong. It is actually flipping the hats on the shocks.
Rebar Wrangler
Old 10-02-2006, 08:55 PM   #29 (permalink)
Carbeaux's Avatar
Not meaning to be obtuse, but could you explain what you mean by that?
Hook 'Em Horns!
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand that...
Old 10-02-2006, 09:02 PM   #30 (permalink)
kartman's Avatar
DOnahoe shocks have a hat at the top that adapts the standard shock mount to fit the coil bucket of the Titan, look at the top of the shock in the pic. Flipping the hat upsidedown apparantly makes the shock a little longer for a bit more lift. I hve not tried it personally.
Rebar Wrangler
shocks and struts, sway bars supertitan Titan Suspension 4 04-15-2006 11:00 AM
sway bars jd1973 Titan Suspension 1 09-23-2005 04:25 PM
Help, Upper A-arm is hitting coil bucket... K-MU Titan Suspension 10 09-03-2005 10:54 AM
Sway Bars or Eurathane bushings? CobraGMike Titan Parts & Accessories 3 04-07-2005 03:53 PM
Anyone know of a source for rear sway bars? Crankrod Titan Performance Modifications 7 02-15-2005 08:23 PM
