Old 10-03-2006, 11:21 AM   #31 (permalink)
KUSTOMZMAN1's Avatar
Re: Removing the Sway Bars and Flipping the Coil Bucket for an Added 1"??
hey kartman i have talked to greg about the sway bar, and was wondering if you would have to re-align the truck after removal? i wouldnt think so but you seem to be more in the know...by the way are you out here in arizona? i see you pics/ videos at sycamore..we should go rompin sometime.or riding if you have a bike (quad here). thanks man
jake
KUSTOMZMAN1 is offline   Reply With Quote
Old 10-03-2006, 11:53 AM   #32 (permalink)
Carbeaux's Avatar
[quote=kartman]DOnahoe shocks have a hat at the top that adapts the standard shock mount to fit the coil bucket of the Titan, look at the top of the shock in the pic. Flipping the hat upsidedown apparantly makes the shock a little longer for a bit more lift. I hve not tried it personally.QUOTE]
Gotcha. The visual made the difference.
Hook 'Em Horns!
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand that...
Old 10-03-2006, 12:13 PM   #33 (permalink)
justrich's Avatar
Originally Posted by kartman
That depends on your perceptions and wants. I liked it better. It takes about 3 minutes to try out. Remove one swaybar endlink fron the truck and drive it around for a couple days. If will feel wierd at first so give it a fair shot. If you dont like it reinstall the endlink, if you like it remove the bar and other endlink
i just want it to handle off roading at high speed better and jumping but not high just a foot or two of the ground. i like my truck not having alot of body roll and im sure that will increase without the sway bar. i guess bottom line i need to try it to see if i like it. my only question is that will this be a bad thing to do when i frequently load 3 dirtbikes in the back which will make the center of gravity higher. i assume it will have a ton of body roll with bikes in the back but will that be a problem at about 40-50mph on dirt roads in mojave, california city. again i will probably have to try it to find out but if anyone has similar experiance please do share. im also still interested in getting another inch out of the front end without hurting performance. im hoping someone tries this mod and shares. i would try it my self but i dont trust my skills on suspension. also not to sound dumb but it seems to me that you could just use a 2inch spacer insted of the 1inch that the kit comes with. im sure there is a valid reason no one has tried or mentioned this but i dont know just an idea.
justrich is offline   Reply With Quote
Old 10-03-2006, 12:31 PM   #34 (permalink)
kartman's Avatar
Kustom, I did not align after removing the swaybar, no issues that I noticed. Yeah Im in Scottsdale and try to hit the dirt once a month or so.
Just. No bar lets the front end work more so I like it better for high speed stuff in the dirt. I regularly load the bed to 500+ pounds of gear and hit the dirt, no issues there either. Try it and see if you like it. Like I said it takes 3 minutes or less.
Using a 2 inch spacer with a DR coilover will cause the upper arm to hit the coilbucket.
Rebar Wrangler
Old 10-03-2006, 12:42 PM   #35 (permalink)
d0va's Avatar
Talking Re: Removing the Sway Bars and Flipping the Coil Bucket for an Added 1"??
would this still happend with the total chaos arms?
Pm for a Signature Request
Check out my Photoshop Signature Album
d0va is offline   Reply With Quote
Old 10-03-2006, 12:59 PM   #36 (permalink)
kartman's Avatar
The DR has an internal limiter which is why you need a spacer with the Chaos arm, otherwise you would not get the extra droop from the arm since the shock would limit it. If you put on a 2 inch spacer then you made the limiter longer basically and even the chaos arm would hit as I recall.
Rebar Wrangler
Old 10-03-2006, 09:48 PM   #37 (permalink)
MississippiTitan's Avatar
Send a message via AIM to MississippiTitan
I dont know If I can do this but over on CT a newbie posted this
"Hi everyone, I have the 4" PRG Performance lift from PRG including DR coils, TC a-arms w/spacer, Deaver leafs, Bilsteins and 2.5" rear blocks.
I have removed the sway bars in order to flip the top hat of the coil bucket. This added an extra 2" to the lift.
Problem is I'm not thrilled w/the ride w/out the sway bars. My mechanic says I need 1" longer stabalizer link kit in order to reinstall the stock sway bar. Wondering if the Hellwig rear sway bar will fit and work or if there is anything else I can add?"
Thanks.
MississippiTitan is offline   Reply With Quote
shocks and struts, sway bars supertitan Titan Suspension 4 04-15-2006 11:00 AM
sway bars jd1973 Titan Suspension 1 09-23-2005 04:25 PM
Help, Upper A-arm is hitting coil bucket... K-MU Titan Suspension 10 09-03-2005 10:54 AM
Sway Bars or Eurathane bushings? CobraGMike Titan Parts & Accessories 3 04-07-2005 03:53 PM
Anyone know of a source for rear sway bars? Crankrod Titan Performance Modifications 7 02-15-2005 08:23 PM
