Old 10-02-2006, 12:25 AM   #1 (permalink)
AgTitan06's Avatar
Drive by wire?
Hey, can someone explain to me what this means, and why does everyone want to get rid of it? What will this help?
Edit: Found some info here: http://en.wikipedia.org/wiki/Drive_by_wire
How can this be disabled with the programmer, and what kind of gains could be possibly see? I think I remember the COBB people saying they will be able to disable this. What will the pros and cons to disabling this?
Old 10-02-2006, 02:25 PM   #2 (permalink)
thejosh's Avatar
Re: Drive by wire?
are you asking why people want to get rid of drive by wire or why is everyone going to drive by wire?
if a vehicle already has DBW.. and if you disable it.. theres no cable that will open the throttle body. i dont see any advantages in getting ride of it.. it only helps out. granted the early stuff sucked and i drove a BMW and their's was bad.
2006 TITAN SE KC 4X4, 7" CST LIFT, FRONT FOX RACING COILOVERS,
REAR 13 LEAF DEAVER SPRING PACK, REAR TC SHACKLES, REAR CST SHOCKS,
17" PROCOMP 6079 W/ BLACK BEADLOCK, 35" BFG-MT,
AMP-RESEARCH POWER STEPS, MAGNAFLOW EXHAUST
thejosh is offline   Reply With Quote
Old 10-02-2006, 02:54 PM   #3 (permalink)
AgTitan06's Avatar
Re: Drive by wire?
I just thought I heard some people saying that is slows us down at high RPMs?
Old 10-02-2006, 04:48 PM   #4 (permalink)
tonyliz1321's Avatar
Re: Drive by wire?
people are trying to change the limitations that nissan built into it like not allowing wot untill a certain speed/rpm not get rid of it entirely
tonyliz1321 is offline   Reply With Quote
Old 10-02-2006, 04:54 PM   #5 (permalink)
StuntDriver06's Avatar
Re: Drive by wire?
full throttle only at and after 4900 rpms, throttle reduced after 5200-5300rpms, only a small percentage of throttle until ~3200 rpms... when a programmer comes out it should give you what throttle you put in and fuel respectively.... i think very impressive gains can be expected...
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 10-02-2006, 05:06 PM   #6 (permalink)
baseballfanz's Avatar
Re: Drive by wire?
I believed the problems lies more in the tranny shift points than the throttle body. Scr38 did a test with a video camera showing the TB wide open at WOT, it does not close like some have though.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 10-02-2006, 05:07 PM   #7 (permalink)
Re: Drive by wire?
where can i find this video? i beg to differ in a friendly manner..
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 10-02-2006, 06:10 PM   #8 (permalink)
llajumpvid's Avatar
Re: Drive by wire?
http://www.clubt*tan.org/forums/showthread.php?t=20786
The shallow end of the gene pool needs some chlorine!
April 04 Armada
Mods: 20% tint, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring (read how to here) , 7" monitor (see it here), video on Navigation screen (how to here) , reverse camera, hood deflector, weathertech vent visors, sunroof deflector, Cascade sound deadener, Street Scene Grille and a fully functioning car-mada-puter, Download fauxdynoV3.0.xls
llajumpvid is offline   Reply With Quote
Old 10-02-2006, 06:16 PM   #9 (permalink)
Send a message via AIM to TIGHTIN
Re: Drive by wire?
Originally Posted by llajumpvid
even after putting in the "I" linky doesn't work.
04' KC Popular w/RF, Truxedo Lo Profile, Deepwater "Blue",
TIGHTIN is offline   Reply With Quote
Old 10-02-2006, 07:30 PM   #10 (permalink)
dawgs77's Avatar
Re: Drive by wire?
On SCR's Armada he did a WOT run. Near shifts his TB would flutter a bit really quick but not really do enough to hurt his performance. BUT....and this is just a BUT...his Armada runs a 14.6....find a Titan without NX that can do that. So maybe for some off reason his is runing differently?????
Now I have looked at alot of data logged from Titans. And that data suggests that the TB closes after 5200 rpms. The v's to the TB becreases.
Now...how much will it affect performance on a Titan. Will with our cam if it infact does what some of us think, I think any gains will be pretty small.
The Titan is cammed for low end power and just isn't lobbed for that high of a RPM. Now if you could get that TCM to drop the shift points to about 5200 where the horrible decline beings you would stay in the titans power range which should greatly improve times.
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
dawgs77 is offline   Reply With Quote
Old 10-02-2006, 08:30 PM   #11 (permalink)
llajumpvid's Avatar
Re: Drive by wire?
try again putting in the "i"
April 04 Armada
Old 10-03-2006, 01:33 PM   #12 (permalink)
Re: Drive by wire?
is his truck an 04? if so i want to see the same thing on an '06
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Fabtech 6" for 550.00 Bucks..... Drive Wire... WhiteTitanSe Titan General Discussion 5 08-14-2006 06:40 PM
Which wire to use? patrickhb Titan Visual & Audio Discussion 1 08-04-2006 09:17 AM
RCA Wire? ...need help markymrk99 Titan Towing & Hauling 4 04-18-2006 07:18 PM
Reverse wire harness- Orange/black wire? BIGT56PA Titan Visual & Audio Discussion 6 09-14-2005 04:51 PM
need info concerning drive by wire mods..if they exist maestro Titan General Discussion 1 06-08-2005 09:28 PM
