Old 10-03-2006, 08:54 AM   #1 (permalink)
Roadrunner's Avatar
Spray in bedliner
I heard you should armorall your spray in bedliner once a year, is this true? Has anyone ever done this?
06 CC SE Big Tow
Roadrunner is offline   Reply With Quote
Old 10-03-2006, 08:58 AM   #2 (permalink)
Re: Spray in bedliner
I can't imagine that it would be for any reason other than cosmetic... I think I heard about a TSB for when they turn white and scaly... The dealer might even do it for you, or at least give you some goo to put on it....
mtofell is offline   Reply With Quote
Old 10-03-2006, 09:26 AM   #3 (permalink)
KUSTOMZMAN1's Avatar
You can get a product from any local spray-in-liner company, its basically like shoe polish for your truck bed. its a black gel you install with a sponge type thing..only for cosmentic reasons, no other...here in arizona spray in liners only look black for about 2-3 months then its all grey. you could also use armorall but then if you ever sit/lay in your bed your going to get oil spots all over you.
KUSTOMZMAN1 is offline   Reply With Quote
Old 10-03-2006, 03:46 PM   #4 (permalink)
2tall's Avatar
A kid at my work has an 04 with the factory sprayed liner and he said it had started to bubble. He also said Nissan has not heard of this before (at least his dealer) but they are repairing it free of charge. He thinks it is something in the air because he hasn't had it happen till he started where I work just this year.
06 Majestic Blue BT/CC LE Fully Loaded DVD/NAV/Leather eXTANG Soft Cover Volant SS Exhaust PRG Level Kit AEM Polished CAI Silverstar Ultras
Active tuning Grounding Kit 2* timing advance
2tall is offline   Reply With Quote
Old 10-13-2006, 11:00 PM   #5 (permalink)
There is no reason to put armour all on your bedliner. Some of the early titans are blister. I am one of the robot tenders that sprays the bedliner in the frontier. In the first few months of building the titans they didn't have flow monitoring on the robots which enabled the flow to get too far off ratio, and could cause a blister later in the field. The problem is was fixed very soon after discovery. The dealer will replace the entire bed or pull out the liner and spray in a new one.
chadrock is offline   Reply With Quote
Old 10-14-2006, 12:39 PM   #6 (permalink)
2tall's Avatar
Lol Funny you say that because a guy at work is getting his re-done soon for the blistering (2004), I wonder how the hell they will fix that. Grind out the old stuff or just give him a brand new bed.
How much for a spray-in bedliner? AgTitan06 Titan General Discussion 8 09-17-2006 07:37 AM
Spray-in Bedliner fix the head Titan Problems & Dealer Service 5 05-16-2005 02:22 PM
what's the best way to clean the spray in bedliner? Sc0rp10n Titan General Discussion 4 05-13-2005 11:53 AM
Best spray-in bedliner OCR Titan General Discussion 23 09-24-2004 11:30 PM
SPray in Bedliner? nopropslaw Titan Parts & Accessories 30 07-21-2004 04:55 PM
