Old 10-04-2006, 12:52 AM   #1 (permalink)
Need help with rear axle breather mod..cant get the new breather threaded
LOL, can someone help me (Yes I tried the search function first).? I am trying to complete the axle breather mod that CJ3FLYR was so gracious to introduce. I read his directions, but I cant get the 1/8mpt into the hole. I realize that it is slightly different than the stock POS 1/8 fitting and have read several posts where members state that the new 1/8mpt will have to be forced into the hole and will cause some minor re-threading. But, for the life of me, I cant get the darn thing even started. I am confident that once I get it "biting" enough, I can force it in the rest of the way. After much research and talking to many mechanics, they insist this is a must do mod as it can save our seals from leaking and help our rear diff/axles breath so much better than the oem factory check valve. So, any ideas from those of you that have done this mod? Any help would be appreciated as I am very frustrated . LOL, thanks!
http://www.titantalk.com/forums/tita...highlight=vent
Paulphilly is offline   Reply With Quote
Old 10-04-2006, 05:31 AM   #2 (permalink)
SmokenMini's Avatar
Re: Need help with rear axle breather mod..cant get the new breather threaded
I had the same problem with mine. I ended up getting a die that fit the factory check valve and re-threading the 1/8" barb about 1/4 to 1/2 way up the threads. Teflon taped' the threads and screwed the thing in. It went right in after I did that. Hope that helped.
2005 Smoke CC BT OR
ProComp Stage 2
PRG Leveling
Deaver Full Spring Pack
Total Chaos upper arms
20" Moto Metal 951's
36/13.50/20" Irok Radials
Husky Liners
Lund Stainless Hood Guard
Lund Tri-Fold Tonneau
Rear diff's be ware....I will break you
Because lifes' too short to drive an ugly truck...
SmokenMini is offline   Reply With Quote
Old 10-04-2006, 08:27 AM   #3 (permalink)
Please forgive my ignorance in this matter, but what exactly is a die? Is this something I can get at a hardware store? And, how do i re-thread the 1/8" barb? Thanks
Old 10-04-2006, 09:54 AM   #4 (permalink)
Clint's Avatar
a tap threads a hole, a die theads something to fit in a threaded hole.
tap= nut , die = screw
You can gat a tap at a hardware store to change your threads or posibly go ask a local mechanic if he'd cut the threads for you. Offer him a few dollars for lunch and I'm sure he'll do it. You need to know what size threads are in the hole.
Clint
You have two choices in life:
Old 10-04-2006, 10:03 AM   #5 (permalink)
pi3yeargrad's Avatar
wow...this is the first time seeing that thread...sounds like a nice quick mod to do hope u get it figured out paul
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 10-04-2006, 12:59 PM   #6 (permalink)
I picked up the correct sized vent tube from toyota. It's large enough so you can use 5/16" tubing, cost about $4 and wasn't in stock. I know nissan makes one but it has a smaller tube and I had already purchased some 5/16" fuel line so I just used toyota's part. Here's the part#(90404-51026) listed as "union".
demo8 is offline   Reply With Quote
Old 10-04-2006, 05:55 PM   #7 (permalink)
Justintoxicated's Avatar
I'd be a bit concerned of tapping the threads without flushing the the metal shavings out of the rear axle....
Old 10-04-2006, 06:01 PM   #8 (permalink)
Burly's Avatar
It cant be as bad as the chunks of metal they already have in them stock
Had..
05 Titan SE 4x4
Color: Blizzard
Crew Cab
Have..
Burly is offline   Reply With Quote
Old 10-04-2006, 06:28 PM   #9 (permalink)
Clint's Avatar
He's not tapping the hole in the rear. He's cutting new threads on the piece going into the rear so there aren't any loose shavings.
Clint
Old 10-04-2006, 06:38 PM   #10 (permalink)
SmokenMini's Avatar
Clint
Right, I definately would NOT tap the rear diff. I re-threaded the fitting going into the rear end. I also kept the check valve incase any warranty issues come up.
2005 Smoke CC BT OR
ProComp Stage 2
PRG Leveling
Husky Liners
Old 10-04-2006, 07:13 PM   #11 (permalink)
links to breather tube and die size? Are the threads fine Metric or course metric?
Old 10-04-2006, 07:52 PM   #12 (permalink)
got_titan's Avatar
thanks for the info....
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, Stillen brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 448rwtq
Old 10-05-2006, 01:03 AM   #13 (permalink)
Does anyone know if the stock vent tube is mpt, Bspt, metric??? I ordered a bspt tube that will hopefully be a direct match to my stock tube and will then mate a mpt/barb 1/8" to the bpst fitting. I just hope that the threads are bspt. Any knowledge or thoughts about what type our breather tube is?
Old 10-05-2006, 08:16 AM   #14 (permalink)
Clint's Avatar
If you can, remove the check valve and go match it up with a nut that has a known thread size/type and you'll have your answer. Many hardware stores have metrics in stock to use as a size guide.
Clint
Old 10-05-2006, 09:25 AM   #15 (permalink)
Good idea Clint. I will do that today and let everyone know for future reference. Thanks
rear axle seal nytitan1 Titan Engine, Transmission & Drivetrain 35 10-01-2007 11:15 PM
Looking for Performance Rear Axle bbomar Titan Performance Modifications 8 08-03-2006 09:04 AM
New Rear Axle titanmoon Titan General Discussion 1 04-06-2006 08:59 PM
Titan rear axle is.... loufish Titan Engine, Transmission & Drivetrain 11 11-09-2004 11:02 PM
TSB on Rear Axle? Slurve Titan Problems & Dealer Service 0 10-07-2004 09:50 AM
