Old 10-06-2006, 04:55 PM   #1 (permalink)
tterrag's Avatar
Fog Light Mounting?
I've tried searching already....
Has anyone mounted any hella angel eyes in the oem locations, can someone please offer a little instruction or advice on how to get them all the way in/or back in those holes? What to mount them to w/ supplied u bracket
I'm having some trouble with these little guys
Thanks
*****Need to know how to attach these*******
06 XE CC 2WD
Granite
tterrag is offline   Reply With Quote
Old 10-07-2006, 12:37 PM   #2 (permalink)
JGM
Re: Fog Light Mounting?
I picked up my optilux 2500's this week, I am going to try to install them this afternoon, when I looked it over earlier this week when putting in the silverstars
I was trying to figure out if I should remove the bracket and get the light where I want it in the housing then drill though the sides of the housing.
I know flimflamman did it, maybe he will drop by and sprinkle a few tidbits of info on us? Or someone else that has done the aftermarket route.
JGM is offline   Reply With Quote
Old 10-07-2006, 02:05 PM   #3 (permalink)
JGM
So I have been plugging at this for an about an hour, my orignal idea of going through the sides with the bolts would be a bad idea, you would need a lot of spacers or washers to fill the void between the light and the housing to tighten the lights up, best way seems to mount the bracket straight back against the end of the housing.
The problem being if you do that, there seems to be no way to get the light back on adjusted and tightened up.
I am has some thoughts of cutting the very back of the housing off so I could get to the back side of the lights, but then what would be the best way to mount them then?
Right now I am just going to hold tight and see what other people say because I do not want to make a mistake I can not undo.
Aftermarket Fog Light Mounting Help? fellowx Titan Parts & Accessories 7 04-12-2005 01:20 AM
Would this light mounting system look goo on a Titan? K-MU Titan General Discussion 7 03-21-2005 05:15 PM
amp mounting bbplayajs Titan Interior Discussion 6 01-26-2005 10:27 AM
SWIX IR mounting scsTiTan Titan Interior Discussion 7 01-15-2005 11:11 AM
Mounting Relays...Where Boone-Titan Titan Interior Discussion 0 12-27-2004 05:13 PM
