I know you get a transmission temperature gauge with the Big Tow package and it is in the instrument cluster, right side.
My question is on Titans without Big Tow can I add that gauge to my instrument cluster or is the tranny temp gauge part of a special cluster for Big Tow only?
I have a 2005 LE CC.
2005 TITAN LE CC
Radiant Silver
51,000 miles
The cluster is different. But anything can be done if you want to spend tyhe money.
- Joe
You can install aftermarket gauge like I did. Do a search.
__________________ Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 480,000 miles and I'm hoping to get 500,000.[/color]
So the cluster has different part numbers, one for non-BT and another for BT?
I come from the GM world and their instrument clusters had individual gauges that could be replaced separately.
I can't say for sure but my guess would be that they do have different part numbers because you can't add the guage to the cluster without replacing the entire cluster. It's simple...one has the guage, the other doesn't. Their designed differently. Can anyone post a pic maybe of the cluster with the guage (I suck at pics here...lol) and another post a pic w/o the guage? Maybe that will help.
- Joe
It might be do-able if the wiring harness/printed circuit (if Titan uses one) is the same. One could cut out the sealed opening...I know that on Ford clusters...the circuit boards are different, depending on what package you have.
FWIW, any titan with a factory tow package, not just Big Tow, has the tranny temp guage. At least my non big tow XE does. Try finding another cluster at a boneyard.
Cheers, Lee S.
Why, Yes...I do think you're a Wanker!!
This was discussed a while back. Although the PC boards for the gauges are identical, you can't buy the gauge itself as an individual part to install. You have to buy the whole BT instrument cluster (about $300 if I recall). Like someone said, all depends on what it's worth to you.
$300 for the BT cluster sounds reasonable for what it is. Especially from a dealership. Now, are there sensors required as well or does the engine computer already have the transmission tempature information?
2005 TITAN LE CC
Radiant Silver
51,000 miles
Cheers, Lee S.
You either have the tow package or you don't. There is only one tow package. If you have the tranny temp guage, then you have the tow package. In 2004 they called it the BIG TOW pkg. Now it's just called TOW PKG. Same exact package.
- Joe
So, you're saying I have the Big Tow package WITHOUT the "big tow" mirrors....factory?
Cool trick .
Cheers, Lee S.
Cool trick .
Cheers, Lee S.
Exactly correct. The "Big" tow mirrors are not available on your XE. It's the only part of the tow package XEs don't get. You have everything else though.
- Joe
All Titan use the same gaugee layout, non BT have that part cover up. If you take the gauge out and cut the cover off where the tranny gauge is you will see the tranny temp gauge minus the needle, not sure if you can get a needle, pop it on and it will work or not.
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
That's very interesting. So if all the sending units and computer mumbo jumbo was in the truck (I'd be willing to bet it has everything already), all that would needed is the needle, and to cut the hole that covers the guage? Surely it can't be that easy.
