Re: Two issues
it's weird, but mine did that too , but actually for some reason when the passenger side goes out they both won't work (or was it the drivers......) anyway, but when the opposite goes out, the other one will still work, i think they might be wired in series, when the first one in line goes out, the other one does too, but if the end one goes out, than the first one will still work,
pull both bulbs, you'll proabaly see that only 1 is actually burned out, replace that one and you probably see they both will now work.
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
