Old 11-10-2006, 12:01 PM   #1 (permalink)
BobNYC's Avatar
Spray-on or add-in bedliner?
The dealer called today....
I specified an add-in bedliner on the '07 SE I ordered. He has found one with the Utility Bed package (has everything else I want) and wants to know if I'm interested. What do you all think of the spray-on liner? Better? The same? Worse?
BobNYC is offline   Reply With Quote
Old 11-10-2006, 12:11 PM   #2 (permalink)
Yahooligan's Avatar
Re: Spray-on or add-in bedliner?
Personally, I'd go with the spray-on. The utility bed is sweet, too, however if you don't really care about that then I'd suggest going aftermarket for it, such as Rhino Liner or Line-X. My initial impression of the factory spray-in is that it's not sprayed on quite as thick as an aftermarket, but I'm not 100% sure.
The slide-in bedliners help almost as much as they hurt. Rocks get underneath and rub away the paint, moisture gets trapped underneath and causes rust (Now that you've had rocks expose bare metal). All in all, I'd avoid the slide-in.
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454
Yahooligan is offline   Reply With Quote
Old 11-10-2006, 12:16 PM   #3 (permalink)
goboilers's Avatar
Ditto!
I've had both and in my opinion spray on is the only way to go.
goboilers is offline   Reply With Quote
Old 11-10-2006, 01:15 PM   #4 (permalink)
BobNYC's Avatar
Thanks for the quick feedback!
Old 11-10-2006, 01:58 PM   #5 (permalink)
Roadrunner's Avatar
The spray n bed liner is awseome. I highly recommend you get it.
Roadrunner is offline   Reply With Quote
Old 11-10-2006, 02:05 PM   #6 (permalink)
ascuro's Avatar
I'd go bare metal over a plastic slide-in. I had a slide-in for about 10 years in my old Chevy, and after taking it out, the bed looked like someone had tried to destroy it on purpose.
The factory spray-in is the way to go imo, but seems less durable than most aftermarket spray-ins I've seen. I have several scratches and gashes from simply pulling stuff in and out.
ascuro is offline   Reply With Quote
Old 11-10-2006, 02:23 PM   #7 (permalink)
PapaRhino's Avatar
Spray on is the way to go!
2004 SE, K.C. 4x4, Silver, big tow, utilitly bed
Banks Monster Exhaust ,K&N stage II cold air intake
Nitto Terra Grapplers 305-55-20, Black Rhino Wheels 20", PRG leveling kit, N-Fab nerf bar, Bilstein 5100.
PapaRhino is offline   Reply With Quote
Old 11-13-2006, 12:25 PM   #8 (permalink)
Titangasm's Avatar
I'm a LINE-X dealer.
The factory Nissan bedliner (by PPG) is WAY thinner than LINE-X or Rhino. I know, I've repaired a few of them. If you decide to get LINE-X, you'll get a nationwide lifetime warranty.
Titangasm is offline   Reply With Quote
Old 11-13-2006, 06:32 PM   #9 (permalink)
BobNYC's Avatar
Am I correct to assume you can add an aftermarket spray-in liner over the factory liner?
Old 11-13-2006, 08:39 PM   #10 (permalink)
Titangasm's Avatar
Actually, no, that would not be appropriate. The factory liner should be removed first and then the new liner installed.
Old 11-13-2006, 09:11 PM   #11 (permalink)
Sentry's Avatar
Same here... I would recommend Spray on liner.
'05 SE CC 4X2 - Deep Water
Mods:
Flowmaster 50 Series 2.25" DIDO
K&N Filter
ARE LSII Tonneau Cover
Full Metal Jacket Spray on liner
Grille Guard w/ Headlight Guards -OEM
Underseat Storage Organizer - OEM
Foglights - OEM
Sentry is offline   Reply With Quote
Spray in bedliner Roadrunner Titan General Discussion 5 10-14-2006 12:39 PM
How much for a spray-in bedliner? AgTitan06 Titan General Discussion 8 09-17-2006 07:37 AM
Spray-in Bedliner fix the head Titan Problems & Dealer Service 5 05-16-2005 02:22 PM
Best spray-in bedliner OCR Titan General Discussion 23 09-24-2004 11:30 PM
SPray in Bedliner? nopropslaw Titan Parts & Accessories 30 07-21-2004 04:55 PM
