Originally Posted by BKW
3 studs per side...there are 6 holes per side...about an inch or so apart...only three are used, depending on where you want the steps to go...the holes are covered by plastic plugs.
Easy install...
Thanks for the quick reply.
Just to make sure I understand what you wrote - that there are 3 studs - one for each bracket - that are on the truck so I just use the nuts that were supplied with the nerf bars. Then there should be a threaded hole adjacent to the stud so I use the bolts that came with the nerf bars.
Is that right?
Thanks again!
