I'm looking for an aftermarket switch so I can run my fog lights when I have my running lights on only. Has anybody heard of such a product. Also I'm looking for a switch to make it when I turn on my high beams both high and low come on. Any help would be appreciated.
I think that the fog lights work when the switch is in the parking light mode and your fog lights are in the on position
2008 SE CC 4X4 RED BRAWN w/popular package, Big tow, Bed utility w/bed extender, Fog lights and back up sensors, Homelink
MODS:
Sirius
TomTom GPS
DIY Intake Mod w/K&N drop in
Activetune Grounding Kit Red wires
Magnaflow Cat-Back
Silverstars
Luminics Pure Blue 6000k fog lights bulbs
Nissan Steprails
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Armada Airdam mod
I did all this without wife knowing
I installed OEM Fogs complete with new turn directional stalk, all in one kit. New stalk has Fog light switch. Fogs only come on in headlight position. My 07 was prewired for the lights.
07 SE KC 2wd 3.35s RocFos
FM 40 (9525454) Dumped No Sec Cats
2* advance (Thanks RB)
K&N Drop In
Mobil 1 Oil
Nissan Fogs
YES your correct I did this mod 3-4 months ago and fog lights stay on w/ highbeam and turn on only w/ running lights ...
chech my thread for detail pict finally got to do some modes!!!
My brother has a chevy tahoe and he baught a small wire relay that makes both low and high beam lights come on when he switches to high. Thats all I want to do with my fog lights and my high beams. My titan came with factory fog lights.
the fog light mod would work for the fog light to run w/high beams lows or just running lights. Is real ea$y... check it out finally got to do some modes!!!
You can do the "jumper" mod like d0va which will allow the factory foglights to come on with parking lights, stay on with headlights or high beam. You will however loose the function of the foglights switch on the headlight stalk. You can also do what I did, take a little more work but it keeps the function of the foglights switch on the headlight stalk. Foglights on with parking lights
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
someone posted a mod where they added fog lights in the lower bumper opening and with that mod, can't you tie into the existing factory fog lights? maybe just add a ground and in-line fuse for each??
with lights like that, you would want to have relays with a separate power wire. Reason being, the factory wiring probably cant handle all the current of both sets of lights.
