Old 12-14-2006, 04:09 PM   #16 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Re: Coolant Smell during Defrost
after looking at the second pic of the first post in this thread
Leaks-should I be concerned? See attached
i seem to have the same COOLANT LEAK
here are some pics .. mine seems further along than the other guys truck in the thread i posted. i know the pics get a little redundant but you get the idea.
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*AT3030XL muffler / 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is offline   Reply With Quote
Old 12-14-2006, 06:20 PM   #17 (permalink)
HudsonValleyTitan's Avatar
Isn't that the tranny oil cooler line or oil cooler? Doesn't look like a coolant line.
- Joe
Old 12-14-2006, 06:53 PM   #18 (permalink)
import2nr's Avatar
im not sure. I just assumed that the first guy who took the pic on the other thread new what he was talking about.
ANYONE ELSE CARE TO CHIME IN ON WHAT THIS LINE IS?
*AIRE TBS
Old 12-14-2006, 06:57 PM   #19 (permalink)
Import
Yes, we have the same leak. After my initial post on this thread, I asked the dealer to pressure test the system to see if my heater core was leaking. They pressure tested the system yesterday to 16 lbs and said there are no leaks. Then I noticed the hose last night, which I am sure wasn't there before, and then tonight the main black hose running from the radiator to the engine I noticed has antifreeze caked on it. No wonder I smell coolant! I know these guys aren't pulling down big bucks but clean up after yourself when you are done! Now I don't know if the mess and the leak on smaller hose was caused by the pressure test/messy mechanic or if they are really leaking!
Thoughts/comments on spraying the engine down with water to see if the leaks come back? I hate spraying the engine down with all of the wiring under the hood.
I do not know if this is the tranny cooler line in my pic and in imports (tranny cooler used radiator coolant, correct?)
thanks
white
whiteLE is offline   Reply With Quote
Old 12-14-2006, 07:27 PM   #20 (permalink)
import2nr's Avatar
thanks for the info whiteLE .. I havnt had the pressure test done yet and i have the leak and the little puddle on the splash-gaurd under the hose. I guess i should point out what i have found or should i let them tell me what and or where they found it....just to see if they even bring up that leak.
*AIRE TBS
Old 12-15-2006, 12:16 PM   #21 (permalink)
import2nr's Avatar
so it turns out i have a crack in my radiator. they did not tell me what or why the hose is leaking .. they did the pressure test and saw a slow drip coming from the radiator. I diddnt see it for myself.
so anyohter problem came up. while checking into my extended warranty they tell me that my warranty was canceled on 04/17/04... about one month after purchasing my truck. however in checking with my bank .. they did not recieve a REFUND CHECK in the amount specified for the extended warranty .
I dont have an answer yet as to what happened and or why it happened. BUt i was told that the only way an extended warranty can be canceled is if the CUSTOMER signs off on it . ANd i did NO such a thing ...
they are supposed to be getting back to me but not for a few hours
anyway the cost of fixing without a warranty would be 785 and some change.
WHat should i do WHo should i talk to and should i make another thread on this as a seperate issue?
*AIRE TBS
Old 12-15-2006, 02:39 PM   #22 (permalink)
Unlike some other makers, Nissan doesn't usually screw the customer due to their mistake. Wait and see what they say, then go from there. Good luck!
- Joe
Old 12-15-2006, 03:37 PM   #23 (permalink)
StuntDriver06's Avatar
yeah give them a chance to make it right and go from there... i doubt they will screw you over, especially if they cant produce a document where you signed off saying you wanted to cancel...
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 12-15-2006, 07:00 PM   #24 (permalink)
import2nr's Avatar
Well As Stupid As This Makes Me Look ... My Wife And I Recieved A Fax From The Dealership With Both Of Our Sigs On The Bottom Of The Cancellation Form ..... But Neither Of Us Can Remeber For The Life Of Us, Signing That Paper ... .. But Even Though They Found That Document With Our Sigs They Still Have Some Explaining To Do About The Cost Of The Extended Warranty Not Being Taken Off The Financing ..... So In Other Words Were Paying "x" Amount For A Warranty That We Dont Even Have ... And There Was No Check Sent Back Ot The Bank In The Sum Of Thewarranty Cost.
Now This Is Unofficial But The Guy I Spoke To Said If They Dont Find Any Proof Of A Check Being Sent Then They Will Either Cut Me A Check In That Amount Or Reimburse The Amount That Ive Paid In Financing The Cost Of The Warranty And Take Off The Cost Of The Warranty From The Original Finance Charges .... Or They Will Reinstate The Warranty ..... But All Of That Is Up In The Air Until Monday.
So They Also Seem To Want To Work With Me On The Cost Of The Repair.. If Things Go Another Route.....becuase I Got It Diagnosed At Another Dealership And I Think They Want To Beat There Price Or Somthing Like That Because They Keep Asking Me What They Quoted Me Over There.
Well Im Sorry For All The Cpas .. I Just Noticed It....
*AIRE TBS
Old 12-15-2006, 07:27 PM   #25 (permalink)
import
I learned a few valuable lessons tonight from my dealer:
1. The coolant hose leak we have is not a coolant leak but a power steering fluid leak. Bring it in and they will order you a new hose. First pic--power steering hose.
2. What I thought was caked on coolant on the main hose is actually a protectant applied to the hose that makes it last longer. Note the picture "Christmas2006" and you will see where I have rubbed it off on the top right while the unrubbed portion still appears dirty. When you rub it, your finger will have a green residue on it. Does everyone's hose look like this? (no sick comments here, please, this is serious business).
3. Don't ever take a water hose to the engine to clean it. (my other cars have been old)
thanks
white
coolant-smell-during-defrost-power-steering-hose-1m.jpg  coolant-smell-during-defrost-christmas2006-006.jpg
Old 12-18-2006, 10:52 AM   #26 (permalink)
import2nr's Avatar
AWSOME... nissan was able to reinstate my extended warranty..
but it takes 30 days for the warrenty to take effect...so they are going to fix it and sit on the bill ... i still have to pay my deductable but thats nothing compared to the cost of fixing it. .. i assume that they did not ever find a check and thought it would be easier to just reinstate .. either way im happy.
oh and the other good news is the radiator is in stock.
*AIRE TBS
Old 12-18-2006, 11:49 AM   #27 (permalink)
Clint's Avatar
Way to go Nissan! This is good to hear as most posts are complaints about how they weren't being fair to a customer.
Clint
You have two choices in life:
Old 12-18-2006, 01:15 PM   #28 (permalink)
import2nr's Avatar
Clint
yeah ... i hear that.. i've had plenty negative posts about dealer services.
*AIRE TBS
Old 12-18-2006, 02:57 PM   #29 (permalink)
Excellent! I knew they'd come through.
- Joe
Old 12-19-2006, 06:58 PM   #30 (permalink)
awesome, just what i would expect from nissan
Born: 11/2006
Mine: 11/30/2006
Click For Mods
