Old 12-19-2006, 10:21 PM   #31 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Re: Coolant Smell during Defrost
so today they fixed my radiator and also diagnosed that leaking hose... its a PRESSURE HOSE for the POWER STEERING FLUID. and they have to order it ... the hose alone is 140.00 bucks and then the cost to install it is 180.00.. I assume the hose is so expensive because its a pressure hose.. but im just guessing...... so i have to go bakc once the part comes in for them to fix it.. atleast its covered under warranty.
Another thing that happened to me today which made me late in taking my truck to the dealer is my battery was dead when i tried to start it this morning.... i've got about 45000 miles on my truck so i guess its about time to replace the batt. ... but the dealer wanted to charge me 43.00 to check it and then if it needed to be fixed it would have been 138.00 bucks for batt./install... so i declined on the batt test and took it to autozone and got it tested for free and bought a batt. for 87.00 total with tax and they even installed it for me at no extra cost.... 87.00 bucks sure beats out 138.00 bucks for a batt. I also picked up a new set of wipers while i was there. bosch icons is the brand and they are awsome .. i cant speak for the long term but they wokred better than any wiper ive ever used on any vehicle .... they are pricey but i think they are worth it .. thye were absolutley silent and left no streaks or anything of the sort. i know htey are new out of the box and ofcourse they are gonna do that but it just seemed better than anything i have bought before... so far....
here are some links to the blades... and if you doi a search im sure youll find more on them
http://jobs.boschusa.com/AutoParts/WiperBlades/ICON/
http://www.autohausaz.com/html/wiper_blades_icon.html
http://www.scoobymods.com/forums/showthread.php?p=21288
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*AT3030XL muffler / 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is offline   Reply With Quote
Old 12-20-2006, 05:24 PM   #32 (permalink)
StuntDriver06's Avatar
ive heard good things about bosch icons... but they are like $22 a piece though..
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 12-20-2006, 05:27 PM   #33 (permalink)
import2nr's Avatar
yes tis true...22.89 for the 24A inch driver side and 21.89 for the 22B inch passenger side.
*AIRE TBS
Old 12-21-2006, 09:00 PM   #34 (permalink)
import2nr's Avatar
okay so im driving my truck yesturday and i punch the gas and i get this huge vibration /hum coming from the front of the truck ... i punched it a few more times just to see if i could tell where it was coming from ... and yes its coming from the radiator.... how you say ... well i dont know how but after i let my truck cool i went to look under the hood .. and i check to see if the radiator is loose... and sure enough i can move it around just by grabbing the spout on the top of the radiator... i assume they forgot some bushings or somthing like that ... never the less .. my part came in for the powersteering hose and im taking the truck in again tomorrow morning for them to fix the hose and also look into the radiator and get that fixed to ...
i would be a little more upset had i not had another reason for going back to the dealer for anohter fix... but since i gotta go anyway it kinda works itself out .. this time around....
ill let yall know how everything comes out.
*AIRE TBS
Old 12-22-2006, 01:26 PM   #35 (permalink)
import2nr's Avatar
so i took the truck to the dealer and they fixed the hose but could not pin point wherethe vibration was coming from and told me they need more time with it but i could not stick around anymore.. so now i have to take it bakc again another day....just for them to fix somthing that was not broken untill i let them work on it... this sucks
this always happens to me when i take the truck in ... they never find the problem the first time.. and i always have to take it bakc for the same thing at least twice.
*AIRE TBS
Coolant smell when engine is under a load dgs1966 Titan Towing & Hauling 3 11-08-2006 01:42 PM
Coolant Smell? Big Azz Rice Burner Titan Problems & Dealer Service 5 03-15-2006 01:50 PM
Slight coolant smell when hot... miketan Titan Problems & Dealer Service 16 02-01-2006 10:07 PM
Coolant smell TuffTitan Titan General Discussion 4 11-03-2004 05:21 PM
Defrost korman100 Titan Problems & Dealer Service 14 07-02-2004 02:05 PM
