Old 11-29-2006, 06:28 PM   #1 (permalink)
ascuro's Avatar
Noise from under cab/feet
There are several threads on what seems to be the same problem, but I can't seem to find anyone who's found the source. It's happening to me now - a clunk or soft thud that sounds and feels like it could be coming from down at your feet.
Could be inside or outside, I can't say for sure - not loud enough to notice with the radio on, and I can't seem to hear it with the window open. It's very similar to the sound of the key fob hitting the dash actually (but that's not it). I've been desperately trying to track down the culprit for a while now - I can replicate the noise sometimes when accelerating, but it's most prominent when going over small bumps or rough patches in the road.
It actually almost sounds like something moving back and forth - there's a louder and softer version of the noise...
ascuro is offline   Reply With Quote
Old 11-29-2006, 06:53 PM   #2 (permalink)
ArmyAviation's Avatar
Re: Noise from under cab/feet
have you loooked under your truck and see if anything is under there?
2008 SE CC 4X4 RED BRAWN w/popular package, Big tow, Bed utility w/bed extender, Fog lights and back up sensors, Homelink
MODS:
Sirius
TomTom GPS
DIY Intake Mod w/Amsoil EAa104 filter
Activetune Grounding Kit Red wires
Magnaflow Cat-Back
Silverstars
Luminics Pure Blue 6000k fog lights bulbs
Nissan Steprails
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Armada Airdam mod
I did all this without wife knowing
ArmyAviation is online now   Reply With Quote
Old 11-29-2006, 09:09 PM   #3 (permalink)
ascuro's Avatar
Yeah, I've checked all over the interior, door, floorpans (as much as possible)...as well as underneath - suspension, steering, balljoints, arms, framerails, exhaust. I'm still totally stumped. Everything seems to be tight and present, yet that sound is still there, hehe.
Old 11-29-2006, 09:34 PM   #4 (permalink)
Put a vacuum in the "under the seat air vents"... I had a golf pencil in one of mine rolling around that drove me crazy until I figured it had to be inside that vent. Maybe something is inside of yours?
'04 Titan SE Crew Cab | 4x4 | Smoke | Off Road | Big Tow
Banks Monster Exhaust
AFE Magnum FORCE Stage 2 Cold Air Intake System
A.R.E. LSII Tonneau Custom Fit/Paint Cover
OEM Bugshield | OEM Step Rails
SE Utility Bed Package
Goodyear Wrangler Pro-Grade Tires w/SilentArmor Technology
autostnmn is offline   Reply With Quote
Old 11-30-2006, 03:15 PM   #5 (permalink)
305hp's Avatar
I have the same issue. I haven't figured it out, so if anyone figures it out, let us know.
305hp-
Banks Monster Exhaust, AEM Brute Force CAI,Window Tint, Access Cover, Billet Grille, PRG Mini-Lift, BFG T/A KO.
Also, 2005 Volvo S60R
"If you don't know where you're going...Any road will take ya there."
305hp is offline   Reply With Quote
Old 11-30-2006, 03:30 PM   #6 (permalink)
reservoirdog's Avatar
Double-check the frame nut to the cab AND esp. the two 14mm gold colored nuts right next to it, on the drivers side. I've seen a few new Titans and one of the 2 14mm nuts was hand tight. Let us know...
"Without the 2nd, all others are gone as well"
2006 4X4LE, QX56 ECM swapped, +2 timing advance, Banks Monster, Volant (true)CAI, Royal Purple 5W30.(yes, that's a mod!!) Stillen front sway bar!! PowerAid TBS, coolant hose by-pass...
reservoirdog is offline   Reply With Quote
Old 11-30-2006, 03:41 PM   #7 (permalink)
baseballfanz's Avatar
Check out this thread
http://www.club*titan.org/forums/showthread.php?t=187&
Remove the * between club and titan
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 11-30-2006, 08:33 PM   #8 (permalink)
TankTitan's Avatar
I'm also having this same issue. It sounds like a loose bolt clanging. It doesnt do it all the time though.
TankTitan is offline   Reply With Quote
Old 11-30-2006, 08:40 PM   #9 (permalink)
808TiTaN_6"35's's Avatar
Yes I to have experienced this problem on numerous occasions. I thought it was just because of my lift. It happens when I go offroading. I thought it was the trac bar or just the body flexing.
*2004 Titan KC 4X4 SE
*6" Pro Comp Suspension Lift
*17X10 Weld Tucsons
*35X12.50 BFG M/T
*Billet 3 Peice Front Grille
*K&N Intake
*Access Tonneau Cover
808TiTaN_6"35's is offline   Reply With Quote
Old 11-30-2006, 09:06 PM   #10 (permalink)
ascuro's Avatar
Mine's a KC, so the under-seat air-vents aren't the culprit (don't have any =)
I'll double-check all the undercarriage bolts tomorrow, but they all seemed snug. Planning on doing another sweep through the interior too.
Been doing a lot of driving for work lately, and so far - I can hear the noise when the driver's window is up, and down maybe an inch or two - any further and it disappears, although I can't tell if it's just the wind noise drowning it out, or if the door/window is the culprit.
Other than that, not much new - it definately sounds like something either shifting, swinging, or rolling back and forth, with one distinctly louder thud, as well as a softer one. And yeah, it doesn't happen all the time - which is why it's so hard (and infuriating) to track down...
Cold Feet EricNY Titan General Discussion 4 03-24-2006 08:52 AM
Heater blowing cooler air by your feet kc^2 Titan General Discussion 7 02-08-2006 02:44 PM
7,000 feet in the Sierras near Carson Pass 37L1 Titan Pictures & Media Post 9 07-12-2005 05:44 AM
Why does my AC smell like FEET? Beaker Titan General Discussion 23 05-04-2005 06:39 AM
Cold Feet? (literally) bvstone Titan General Discussion 25 02-05-2005 11:28 AM
