Old 11-30-2006, 04:40 PM   #1 (permalink)
StuntDriver06's Avatar
Differences of the 07...
i just got an 07, so i wanted to point out some differences i have noticed so far and will post as i find more.
front doors shut tighter, no more loose look when dooors are closing (KC)
better looking exhaust tip
seems to really pull with more authority (though the lower gear ratio could be throwing me off)
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 11-30-2006, 05:53 PM   #2 (permalink)
MuskyHunter's Avatar
Re: Differences of the 07...
Congrats on the '07!
Other observations;
Throttle is more progressive. Not so sensitive when going over bumps.
Drive shaft is using some kind of acoustical treatment or different alloy so that it doesn't transmit as much driveline noise.
Better low end torque. Easy to get to speed without excessive shifting.
Different shift points and progressive slide into lockout torque converter mode.
Less tendancy to upshift under light peddal pressure. Easy to make moderate speed changes.
Fit and finish is improved. No interior rattles to date.
Brakes feel more firm.
Less bed shake.
Better gas mileage to date.
Seems to handle better for some reason, but that is subjective.
Different starter. Faster and different sounding (higher pitched).
Less of a tendancy for high rev's on initial starting of vehicle.
Noted on the door observation, they do fit and close nicer.
Carpet hugs floor hump better, less loose all around.
Labeled switches for heated seats with hi/low text (never could keep that straight).
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage : BFG Long Trail TA Tour Tires: Bilstein 5100 and Icon Shocks
www.secretlake.net
Old 11-30-2006, 05:57 PM   #3 (permalink)
yeah i noticed the starter too, i was just going to post that... my brakes feel less firm than my 06, but i think there is a procedure for brake pedal adjustment, which is supposed to change the feel slightly... and it does pull to the left, so dealer will have to fix this...
fit and finish definately improved... armrests are even tighter, hope these seats dont squeak...
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 11-30-2006, 05:58 PM   #4 (permalink)
oh, i did notice that it rides better too, that could be due to the 4x4 or the OR package though....
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 11-30-2006, 06:06 PM   #5 (permalink)
As for the ride, it feels like the rear axle is connected. My '05 felt like the back suspension did whatever it wanted. This truck feels like the axle and suspension are one. Less clunking and drifting over rough surfaces. Shocks may be different but my old truck never felt as good as this one.
www.secretlake.net
Old 11-30-2006, 06:07 PM   #6 (permalink)
I am surprised you got the truck. The other day in a post it looked like you gave up. Did you get hooked up with sting77 for the VPP discount?
www.secretlake.net
Old 12-01-2006, 08:05 AM   #7 (permalink)
i did give up until they called me at work the next day desperate for a sale, they knew when i walked out they lost 2 sales because my wife traded her grand cherokee in after i got my deal... so he basically just gave me what i wanted in the first place.. i basically am just paying $50 more a month, not too bad for OR and BT.... no i didnt get the vpp discount.... thanks anyway sting..
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 12-01-2006, 08:06 AM   #8 (permalink)
this truck seems to drift in the lane a lot, my 06 never did at all..... any input?
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 12-02-2006, 02:26 PM   #9 (permalink)
Play around with your tire pressure for drift. I usually have my rear tires 1-2 psi lower than the front. Less understeer that way. I find that the truck tracks better with different front and rear tire pressures. When I got the truck they had all the tires up to 48 lbs. I run them 38 front, 36 rear for general driving, bump each up 2-4 lbs when towing my boat.
With a new truck, the back end sits up high. Same with my '05. Once I started to load the truck and tow, loading the springs seemed to settle everything down a bit. Over time, the back end didn't stick up as high unloaded. Maybe less weight bias when more level than raked? To test that theory, get 8 tubes of sand and put them in your bed for winter. The truck should track differently.
www.secretlake.net
Old 12-02-2006, 02:31 PM   #10 (permalink)
FuzzyLogic's Avatar
48lbs.? I thought the max is 35 psi (on the 17 inch rims). That;s what my tires say.
It's not rocket surgery.
'06 CC 4X4 SE Born Oct. 05
Big Tow
Eclipse GPS Navigation/DVD/CD (Dealer Option)
Smoke
World's fastest beer cooler (see photo gallery for explanation)
FuzzyLogic is offline   Reply With Quote
Old 12-02-2006, 10:39 PM   #11 (permalink)
ZubbyZu's Avatar
Mine stopped drifting after the tire pressure was reduced from 45 to 35 psi and the wheels road force balanced. Apparently the pre-delivery checklist did not include the tires..
ZubbyZu is offline   Reply With Quote
Old 12-02-2006, 11:17 PM   #12 (permalink)
Musky
I think I may have what you are describing. When the steering wheel is straight, the vehicle pulls right (within a hundred feet, it will be on the shoulder). The surgeons at my dealer state its the grade of the road and the truck is meant to do that for safety. So, now 98% of the time my steering wheel is turned 10-15 degrees to the left. I run about 32 lbs in each tire.
Zubby--is roadforce balancing different than standard balancing? What was the charge? I have had my tires rotated but never balanced.
thanks
white
whiteLE is offline   Reply With Quote
Old 12-02-2006, 11:40 PM   #13 (permalink)
I do realize vehicles are set up to drift to the right for safety. I think what he is describing is how much corrective steering is needed to keep the vehicle straight, not a result of the right bias. Of course, crowned roads, cross winds, etc. have an effect on this,
I do find that higher inflation exaggerates this characteristic, especially on crowned roads. As with my old truck, it seemed to track better over time requiring less steering effort and dialing in the tire pressure helped a lot. As for the different tire pressures front and rear, that was something I was always attentive to for autocrossing to balance out handling.
www.secretlake.net
Old 12-02-2006, 11:41 PM   #14 (permalink)
sudden urge's Avatar
Originally Posted by whiteLE
Musky
thanks
white
Well imo what the dealer told you is a bunch of bullshyt. Only reason I say that is because mine never drifts, unless there is a strong wind pushing on one side and that's not often. I'm running 35 psi in all 4 Goodyears.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 12-03-2006, 07:29 AM   #15 (permalink)
cccagle30's Avatar
Musky
thanks
white
Mine drifted right also. My dealers response was" they chain them down so tight on the big rig, it knocks the alignment off." solution was road force balance and alignment. no charge. and now all is good.
RED BRAUN 07 KC SE
Scangauge
15% tint
Tonneau
XM
DON'T ASK TO BORROW MY TRUCK, BIKE, OR WIFE. BECAUSE YOU COULD SLING A ROD IN ANY OF 'EM
cccagle30 is offline   Reply With Quote
Volant Gen 2 vs. Gen 3 differences GreenT Titan Performance Modifications 4 01-08-2006 09:35 AM
Differences in Big Tow mirrors gstlouis Titan General Discussion 8 10-31-2005 07:41 PM
Differences Between 4x2 and 4x4 mnmsmith Titan General Discussion 14 07-07-2005 10:36 AM
04-05 differences Ed Perkins Titan General Discussion 13 02-22-2005 02:40 PM
bed differences Clint Titan General Discussion 2 01-21-2005 10:27 PM
