Old 12-09-2006, 10:03 PM   #16 (permalink)
TankTitan's Avatar
Thumbs up Re: Scraping Noise When I Turn or Hit Brakes Hard!!!!
I called the dealership and asked how much they would charge for a rear brake job and hey said 199.00. I'm going to be able to buy the brake pads and have the rotars turned for $50.00.
TankTitan is offline   Reply With Quote
Old 12-10-2006, 09:09 AM   #17 (permalink)
Please point it out if I am missing something but you were supposed to get new rear pads and have the rear rotors turned during the "brake job."
A while ago I downloaded this attachment from TT. Maybe you can use to your benefit.
white
whiteLE is offline   Reply With Quote
Old 12-10-2006, 09:13 AM   #18 (permalink)
The rear rotors are easy to get on & off. The fronts may require a little muscle or a good air impact wrench.
Old 12-14-2006, 04:20 AM   #19 (permalink)
TankTitan's Avatar
Had the rear rotors and brakes changed in 1 hour last night. This was the easiest brake job ever.
Old 12-14-2006, 05:22 AM   #20 (permalink)
BKW
Originally Posted by whiteLE
Back brakes down to the wear indicator? How many miles do you have on yours? The front brakes usually go first as they do most of the work. It is odd the back brakes are out already.
white
It's not uncommon for people to drive with the E-brake on...or sometimes it doesn't release all the way. That'll take the rear pads down to the rivets.
Rear brakes should last at least 50,000 miles under normal conditions.
BKW is offline   Reply With Quote
Old 12-14-2006, 06:56 AM   #21 (permalink)
Negatory, the e-brake operates shoes which drag on a drum and have nothing to do with the pads on the rear calipers. Leaving the e-brake on will just take the e-brake shoes out.
Old 12-14-2006, 02:55 PM   #22 (permalink)
TankTitan's Avatar
Yeah I agree with bestatchess. When you pull the rotar off the emergency brake is inside like a drum brake. Dont think the rear pads have anything to do with the emergency brake.
Old 12-14-2006, 03:21 PM   #23 (permalink)
BKW
OK...I based my answer on 50 some years experience with cars/trucks that the E brake works off the rear wheels....so tell me, please...how does the E brake operate on a Titan.
When you say shoes in a drum...are you saying this is the old Chrysler style E-brake that had a drum on the back of the trans..which clamped the shoes to the driveshaft? I thought those were outlawed years ago.
My turn to ask for an answer...
Old 12-14-2006, 04:01 PM   #24 (permalink)
The e-brake drums are located inwardly of the rear rotors.
http://www.titantalk.com/forums/atta...c?d=1104241784
Old 02-12-2007, 09:08 PM   #25 (permalink)
jaho1979's Avatar
Did you change the rotors as well? What did you use?
2006 Crew Cab 4x4 LE
jaho1979 is offline   Reply With Quote
Old 02-12-2007, 09:42 PM   #26 (permalink)
SOCALTITANKC4X4LE's Avatar
He said He was going to have the rotors turned. So I assume he did.
2005 Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b][color="Blue"]BLUE LED DASH LIGHTS MOD
1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads [b][color="Red"]487,000 miles and I'm hoping to get 500,000.
SOCALTITANKC4X4LE is offline   Reply With Quote
4x4 Hard to Turn is this Normal? ScottCocoaBeach Titan Problems & Dealer Service 9 11-12-2006 09:49 PM
Front Brakes Noise and Jutter on first 2-3 brakings in the morning sedonaguy Titan General Discussion 3 07-13-2006 09:09 PM
Brakes making a noise after rim replacement TitanConvert21 Titan Wheels, Tires & Brakes 15 04-05-2006 01:18 PM
Clanking Noise From Front Drivers Side Brakes When Towing gravitywerx Titan Problems & Dealer Service 3 07-08-2005 09:37 AM
Hemi Brakes vs Titan Brakes Bayou Titan Titan General Discussion 4 02-01-2004 07:45 PM
