Old 12-10-2006, 03:22 PM   #1 (permalink)
goval's Avatar
I need help ASAP
My truck won't start. I was installing a remote starter yesterday, stopped last night because it was too cold, then continued on this morning. When I finished installing it, I went to test it, and it worked, but the trauck wouldn't start. So I though the battery was dead, then decided to to a jump start and nothing. Disconnected everything again, and threw 1 1/2 days worth of installation to the trash, and the truck still won't start. It tries to, but it doesn't pick up. All the accessories inside the truck works, but the truck won't start. Checked all the fuses and everything is fine. I had to change the ignition fuse on the engine, but still the d@m truck won't start. I don't know what else to do.
As far as I know there is 3 fuse boxes, 1 on the passenger side, and 2 behind the battery, all are good, even the ones on the battery terminal.
07 Charger 3.5.
-Anderson B.
goval is offline   Reply With Quote
Old 12-10-2006, 03:29 PM   #2 (permalink)
gixxer0.6g's Avatar
Re: I need help ASAP
That is exactly why I haven't put one in yet. Me and electricity don't go well together. If it's turning over it sounds like you're not getting fuel, but you said you checked all the fuses? I'm sorry, I don't know.
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
gixxer0.6g is offline   Reply With Quote
Old 12-10-2006, 03:33 PM   #3 (permalink)
goval's Avatar
It's cranking, but the engine won't start. Also the truck is sitting in an angle in my driveway, with 1/4 tank of gas.
07 Charger 3.5.
-Anderson B.
Old 12-10-2006, 03:39 PM   #4 (permalink)
Does your Titan have the vehicle immoblilizer? Sounds like it might from what you are describing. Had the exact same problem installing a remote start in my Titan, come to find out that antenna that wrapped around the ignition module had the antenna loop disconnected inside the plastic connector...fun, fun, fun.
exilepa is offline   Reply With Quote
Old 12-10-2006, 03:44 PM   #5 (permalink)
gabriel c.'s Avatar
all your wires back to oem? i see you have an xe do you have a chip on the key? i have an xe too so probably not. did you cut the tach wire for signal during installation? is it reconnected?
third coast titans
gabriel c. is offline   Reply With Quote
Old 12-10-2006, 03:49 PM   #6 (permalink)
gabriel c.'s Avatar
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2005 / Remote Start
[PRINT THIS PAGE]
12volts green (40A) + ignition harness
Starter brown + ignition harness
Second Starter lt. green or blue/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory purple + ignition harness
Keysense red/blue to black/red + ign harn or BCM R of column, pin 37
Power Lock blue - driver door module in door
Power Unlock red (double pulse) - driver door module in door
Lock Motor purple 5wi BCM to right of column, pin 65
Unlock Motor green 5wi BCM to right of column, pin 59
Parking Lights+ red/blue + dimmer switch on dash
Parking Lights- N/A
Hazards white/black - BCM to right of column, pin 29
Turn Signal(L) green/black + BCM to right of column, pin 60
Turn Signal(R) green/yellow + BCM to right of column, pin 61
Reverse Light green/white + inside rearview mirror
Door Trigger see notes - BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is red/blue in pin 12. The LR door trigger is red/yellow in pin 48. The RR door trigger is red/white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision blue - BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use red/white in pin 62 at the BCM.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire red/green or red/black + brake pedal switch
Parking Brake green - parking brake switch or cluster
Horn Trigger red/white - horn switch
Memory Seat 1 lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
Door Lock Interface Required:
No Type:
Data Bus
Part #: IM-Nissan-1
Notes:
Smart Starter Kill Relays: Not Available
these are your wires, with the exeption of the keysense and the factory alarm since i see you have an xe and most of the xe dont come with factory alarm or keysense, check and see if you missed the second starter wire.
third coast titans
Old 12-10-2006, 03:52 PM   #7 (permalink)
ThatGuy's Avatar
I was buying one recently, got to the check out and the guy wouldn't sell it to me! He said go ahead and install it if you want to mess up your computer. His advice was to only get that done by a dealership or someone who can reprogram your computer because just adding something like that yourself isn't going to work and your onboard systems are not going to like it.
Just thought I'd pass on what I was told.
I hope you get it sorted.
ThatGuy is offline   Reply With Quote
Old 12-12-2006, 03:11 AM   #8 (permalink)
TankTitan's Avatar
Question Re: I need help ASAP
Did you get your truck running? Also did you have clean cuts and good solder connections when you were installing the RS?
TankTitan is offline   Reply With Quote
Old 12-12-2006, 12:12 PM   #9 (permalink)
gabriel c.'s Avatar
hes over at ct.
third coast titans
need help ASAP HVACman Titan General Discussion 2 07-12-2006 07:22 PM
need help ASAP HVACman Titan Visual & Audio Discussion 0 07-11-2006 05:35 PM
Need help ASAP... Please... K-MU Titan General Discussion 11 05-25-2005 04:42 AM
Tried some 20s, need PRG asap... K-MU Titan Suspension 4 05-17-2005 01:20 AM
I need help ASAP! virus Titan Problems & Dealer Service 12 10-30-2004 03:34 PM
