Old 12-16-2006, 12:53 PM   #1 (permalink)
Help with volunteer ambulance lights for brother's Titan.
Howdy all,
My brother has asked me to set his truck up with some lights since he is on the ambulance squad.
Any examples would be extremely helpful.
I was thinking:
Two LED lights in the grille
Strobes at 4 corners
(can't post URL's yet), if anyone wants to post them for me I could PM them to you).
Thanks,
John
Hubjeep is offline   Reply With Quote
Old 12-16-2006, 12:58 PM   #2 (permalink)
baseballfanz's Avatar
Re: Help with volunteer ambulance lights for brother's Titan.
http://videos.streetfire.net/search/...25008f16ae.htm
http://videos.streetfire.net/search/...2500913953.htm
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 12-16-2006, 05:17 PM   #3 (permalink)
ptvolly's Avatar
What state are you (your brother) in? A lot of states have a rule of 360 degree visible warning. Most likely you can get by with it depending on your state and the department he will be running for.
It's a lot more expensive, but the more LED used, the better. If he's (you) aren't planning on having an actual lightbar of any kind, I wouldn't mess with strobes at all. Why? Because of the following:
**You have to drill (usually 1") a hole in your light and have to seal it well to keep out moisture. Not a huge deal, but a PITA if he gets rid of the truck
**about 98% of strobes need a seperate power supply, just add's to cost and wiring.
**strobes do burn out and fail (not as much as halogen, but more so than led)
I haven't done anything to the Titan, but have had emergency lights on several other vehicles and still work for a fire department where we replace haologen and strobe bulbs constantly, but never mess with the LED's.
check galls.com for some idea's, then search on ebay... they don't allow red or blue to be sold, but if you find what you like, email the seller as most will arrange the proper color's.
PM me if you have some more questions....
'05 Smoke CC LE 4X4
PC 6" Stage 1
PC 8188 18X9
PC Xtreme A/T 325/65/18
Bully Dog / Magnaflow "cat-back" / Tint / NISMO CAI / 6k HID / Westin Bull w/ PIAA lights / Truxedo / Carriage Works Grill / Airlift rear bags / Bushwacker Pocket Flares
My super duper MPG doubler- a 1996 Grand Prix coupe!
ptvolly is offline   Reply With Quote
Old 12-16-2006, 08:19 PM   #4 (permalink)
titanpat57's Avatar
Hey Hub,
Heres a slick outfit...not sure of the color choices...Good Luck
2006 4x4 CC Radiant Silver LE - Lazer Lite Cover - Volant CAI and Tails - Keyless Entry (thx BBF) - Big Tow LED Turnsignal Mod - Handmade LED Backup Lights - Remote Start - Front AirDam - Front Tint - Ventshades - SS Sills - SS Tailgate Cover - SS 3rd Brake Cover - Bilstein Struts - As many friggin' LED'S I can get my hands on!
titanpat57 is offline   Reply With Quote
Old 12-17-2006, 05:52 AM   #5 (permalink)
Originally Posted by titanpat57
Hey Hub,
Thanks for the link, that is exactly what I am looking for to mount in the grille.
The seller: strobelightking is only a few towns away from me!
Old 12-17-2006, 07:31 AM   #6 (permalink)
Thats my truck!!! Thats a little over $1100 in lights and very concealed so it looks like nothing is there when turned off. If you need location to buy just PM me.
Old 12-17-2006, 07:38 AM   #7 (permalink)
I like the the leds too but I havent had any probs with my strobes and I have had them for almost 2 years and probably use them way more than any police of fireman. They are on almost every day all day. I can leave them on for over 5 hours without starting the truck without running the batt. down. Cant say that for a light bar with motorized flashers thats for sure. You do not have to seal the lights after the install. Any moisture that gets in is very quickly burned off by the lights once turned on. But it is always better to drill the best hole and seal if you want. I just have a rubber foam washer to seal them. It took about 4 hours to install the 4 corner flashers and about 3 hours for the ones in the grill and back window.
Old 12-18-2006, 07:29 AM   #8 (permalink)
ptvolly's Avatar
Certainly, strobes will absolutely get the job done and as with yours, I've seen some GREAT setup's using strobes.
I just prefer LED's now since the price has come down and most of the flash patterns are easily selectable without a seperate power supply/controller. I think the visibility of them is higher than strobes too (at least during dawn/dusk hours).
I certainly wouldn't spend the money for a halogen light bar, not worth it compared to anything else on the market, and like you said, takes a huge electrical load.
Can't go wrong with LED or strobe...
'05 Smoke CC LE 4X4
PC 6" Stage 1
PC 8188 18X9
Old 12-18-2006, 06:19 PM   #9 (permalink)
Agreed! A lightbar is not worth it considering what is on the market now. The only thing I dont like about LED's is they start to fade in visibility anymore than 35 to 40 degrees off center. The strobes can be seen from everywhere but draw a bit more power than the LED's and the LED's draw next to nothing.
Old 12-18-2006, 10:27 PM   #10 (permalink)
Just-in's Avatar
www.thefirestore.com and Galls are a good place to get your lights. Maybe even a wig wag for the headlamps?
Does your state have the rule like CA where you need one continuiously burning red lamp visible for 1000 ft? I'm not sure if the LED's will reach that far...
Old 12-18-2006, 10:53 PM   #11 (permalink)
Yellomantis's Avatar
I found these guys when we needed something at work. check em out, they are a little on the pricey side, but top notch quality.
http://www.code3pse.com/
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
www.myspace.com/yellomantis
Old 12-19-2006, 05:04 PM   #12 (permalink)
Here are the pics you requested in your PM.
Pic 1 - LED's in the grill
Pic 2 - Strobe power box mounted under seat
Pic 3 - Only visible wires between the passenger and kick plate. There are 4 holes drilled to the outside under the kick plate.
Pic 4 - Wires coming out under the kick plate to outside.
Pic 5 - Wires running down stock wire bundle attached by zip ties.
More coming....................
help-volunteer-ambulance-lights-brothers-titan-leds.jpg  help-volunteer-ambulance-lights-brothers-titan-strobe.jpg  help-volunteer-ambulance-lights-brothers-titan-strobe2.jpg  help-volunteer-ambulance-lights-brothers-titan-strobe3.jpg  help-volunteer-ambulance-lights-brothers-titan-strobe4.jpg
Old 12-19-2006, 05:08 PM   #13 (permalink)
Pic 1 - Rear mounted LED's there are 6 all together in the back window.
Pic 2 - Switch set up for strobes
Pic 3 - Connection behind switch. Simple Cat 5 cable to keep everything clean and VERY easy to run wire.
Hope this helps you!
help-volunteer-ambulance-lights-brothers-titan-strobe5.jpg  help-volunteer-ambulance-lights-brothers-titan-strobe6.jpg  help-volunteer-ambulance-lights-brothers-titan-strobe7.jpg
Old 12-31-2006, 10:55 AM   #14 (permalink)
The LED behind the front grille is going extremely well! Once I have enough posts I will put up some pics, lol.
Anyway,
I am concerned with where I should install the front strobes. I removed one of the massive headlight housings (which I do not want to even imagine how much costs). There is clearance underneath the headlight portion to drill for a strobe, but the reflective bottom of the light slopes up where the housing bottom remains flat, this will leave the base of the strobe bulb obscured by the reflector inside the headlight.
Any ideas would be great. I plan to remove a taillight later.
Old 12-31-2006, 11:07 AM   #15 (permalink)
Just-in's Avatar
Anyway,
why not just wire a wig wag into the headlights and use them as strobes?
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 06:33 PM
Titan LED Tail Lights TN Titan Titan Parts & Accessories 4 06-25-2006 07:46 PM
Looking for FOg lights for 2005 XE Titan Methu969 Buy/Sell 3 03-11-2005 06:30 PM
Gauge lights not lightning up when i turn on lights??? ChadEberly Titan Problems & Dealer Service 4 11-15-2004 12:17 PM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 08:06 PM
