Old 12-28-2006, 12:14 AM   #1 (permalink)
Vehicle Dynamic Control Switch Install
Just wondering if anyone has installed the VDC switch in a titan that did not come from the factory with it.
I went up in the snow this last weekend and I was fighting that darn thing the whole time, it was a real bummer. My lexus has the same thing but when I tunr the VDC off you can spin your tires until they fall apart (and they will ). From what I have read, the Titan works the same way. Iif I can turn the VDC off then that should stop the engine from closing the throttle body on me when I don't want it to.
My question is, has anyone who has taken the stereo trim apart noticed an extra wiring harness plug for the VDC switch? I have the rear lock, and tow switch, but the spot for the VDC switch is plugged. I found the VDC switch online. I'd just like to know if the harness is there before I rip everything apart
Thanks,
Y
raceprep_engineering is offline   Reply With Quote
Old 12-28-2006, 02:17 AM   #2 (permalink)
chunko's Avatar
Re: Vehicle Dynamic Control Switch Install
If you have VDC, you already have a switch to turn it off don't you?
Are you confusing this with ABLS (which, as I recall relates to breaking being applied to slipping wheels, not sure of the affect it has on the TB)
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is online now   Reply With Quote
Old 12-28-2006, 08:40 AM   #3 (permalink)
loufish's Avatar
I've never heard of it being pre-wired already into the harness.
There's not much you can do, IF you had VDC the switch would be there, no switch, no VDC...
If I can turn the VDC off then that should stop the engine from closing the throttle body on me when I don't want it to.
Since you don't have VDC, you can't turn it off...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 12-28-2006, 09:34 AM   #4 (permalink)
Well, every other car I've owned has one wiring harness for all the different typ eof model (XE, LE,SE, etc). I was watching the ABLS light in my dash while slipping but it was also cutting out my throttle. I'm willing to bet that if I did install that VDC switch, that I could at least turn the throttle control off, and thats what I want to do. (good for burnouts anyway)
Old 12-28-2006, 09:45 AM   #5 (permalink)
loosenut's Avatar
Nissan does not use the same wiring harness for the XE, SE and LE models. Just ask anyone that added factory fog lights to their XE.
Like others have stated, if your truck has VDC, then you should have the switch. I believe the VDC is controlled through the ECU, and their are several ECU part numbers according to what I have read on the forums. If you want to do burnouts, then do the burnout mod. It works like a champ! ABLS doesn't cut the throttle, but rather applies the brakes to the slipping wheel.
Loosenut
Mods. Injen Intake and Magnaflow CatBack
loosenut is offline   Reply With Quote
Old 12-28-2006, 10:00 AM   #6 (permalink)
baseballfanz's Avatar
You could always get Up Rev tune, I can do burnout now with out the mod.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 12-29-2006, 06:50 AM   #7 (permalink)
leeroy300's Avatar
loosenut if you have ever been in 4 wd and the abls has engaged you would know that yes it cut fuel supply !!
If it floats, it's fries
leeroy300 is offline   Reply With Quote
Old 12-30-2006, 12:08 PM   #8 (permalink)
Yeah, I doubt its only applys braking., it sure feels like something else.
I'm going up to the snow this weekend and going to pull the ABS fuse and see what happens. I might still take the dash apart just to see whats back there.
Old 12-30-2006, 12:11 PM   #9 (permalink)
I didnt' see nothing back there when I had my radio out, but then I didn't look too hard either. Let me know what you find.
Nissan ODB2 Codes
Old 12-30-2006, 01:01 PM   #10 (permalink)
loosenut's Avatar
What happens when you introduce a load to your engine? The RPMs drop. ABLS is applying the brake to the slipping wheel. That is gonna feel like it's taking away power because the RPMs drop and you didn't control it.
I'm not locked into this opinion, but I think it's logical.
Loosenut
Old 12-30-2006, 06:49 PM   #11 (permalink)
yeah, I read through my manual and it doesn't say that the ABLS sytem cuts throttle, it sure feels like it though.
Old 01-07-2007, 02:28 PM   #12 (permalink)
kirk94's Avatar
Did you ever figure anything out on this? I have the same issue with my VDC. NO SWITCH to turn it off and cant even pull out in traffic in the rain without my truck shutting down on me, real pain in the butt. Let me know, would love to fix this issue.
kirk94 is offline   Reply With Quote
Old 01-07-2007, 02:42 PM   #13 (permalink)
HudsonValleyTitan's Avatar
ABS doesn't cut throttle. Only trucks equipped with VDC will cut power.
- Joe
Old 02-05-2007, 08:56 AM   #14 (permalink)
OMNIHUGE's Avatar
Send a message via AIM to OMNIHUGE Send a message via Yahoo to OMNIHUGE
Ok I've been searching for something like this and I don't care about VDC cause I don't have it. I'm looking for a mod or switch if anyone has installed it, that will disengage b-lsd so it does not work. I would love a mod with just a switch to cut it off, because it's real hard to do donuts and other fun stuff in the snow with this on. If anyone has done this or knows where a link would be, I'd appreciate it!
Boy he gave me a hell of a frisk, he was firm, but incredibly respectful at the same time. You guys are pros.
OMNIHUGE is offline   Reply With Quote
Old 02-05-2007, 01:09 PM   #15 (permalink)
jessefrank's Avatar
If you have an 04-05 titan with the E-locker, I'm 99.9% sure that you do not have VDC. Those two options are only avaliable on the 2006 and up titans.
Read here: You may have VDC and no OFF switch.
Finally Got Vdc Off Switch!!
jessefrank is offline   Reply With Quote
Vehicle Dynamic Control (VDC) For XE? RigginMan Titan General Discussion 7 10-08-2006 07:33 PM
Vehicle quiver... Flight Test Titan Suspension 4 08-18-2005 01:15 PM
Anyone ever install a kill switch? Retriever Titan General Discussion 18 06-13-2005 05:13 PM
nc vehicle law?? wmtom Off-Topic Discussion 2 05-14-2005 10:49 PM
Need wiring diagram for kill switch install. JARHEAD Titan Interior Discussion 2 09-27-2004 03:46 PM
