Old 12-30-2006, 11:35 AM   #1 (permalink)
Taylor's Avatar
2" spacer on top of coilover
Is it safe to use leveling kit spacers on top of new dr coilovers?
Taylor is offline   Reply With Quote
Old 12-30-2006, 12:46 PM   #2 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
Re: 2" spacer on top of coilover
i don't believe so, but someone correct me if i'm wrong.
No more sig for me
i<3mytitan is offline   Reply With Quote
Old 12-30-2006, 03:28 PM   #3 (permalink)
SmokenMini's Avatar
Greg (PRG) set me up with a custom set for my ProComp coilovers. It netted me about 2" total more lift. Talk to him, he will make you a set.
2005 Smoke CC BT OR
ProComp Stage 2
PRG Leveling
Deaver Full Spring Pack
Total Chaos upper arms
20" Moto Metal 951's
36/13.50/20" Irok Radials
Husky Liners
Lund Stainless Hood Guard
Lund Tri-Fold Tonneau
Rear diff's be ware....I will break you
Because lifes' too short to drive an ugly truck...
SmokenMini is offline   Reply With Quote
Old 12-30-2006, 04:00 PM   #4 (permalink)
loufish's Avatar
The DR shock can be set up for 0"-3" lift by itself, I guess you could set the DR to zero lift, but when the suspension tops out the upper control arm will hit the coil bucket because the shocks acts as travel limiter, and you just moved the limiter 2" down...
You may be able to get away with above by going with Total Chaos UCA...
I still see possible problems...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 12-30-2006, 08:11 PM   #5 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Hit Greg up, he makes custom spacers to be run w/ the DRs. You will have to run the TC upper a-arms as well.
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
spacer on dr coilover Taylor Titan Parts & Accessories 0 12-30-2006 11:14 AM
PC 6" Lift, with PRG spacer? PC Helper Spring? ptvolly Titan Suspension 2 05-12-2006 02:17 PM
PRG 2" Spacer Lift alee27 Buy/Sell 2 02-03-2006 12:16 PM
LIFTING COILS LIFTS FRONT END 2.5" NOT A SPACER neworleansmike Buy/Sell 19 03-18-2005 08:42 AM
Daystar alternative 2" spacer?? S4Titan Titan Suspension 3 07-07-2004 07:44 AM
