Old 01-03-2007, 09:43 AM   #1 (permalink)
Firewall access for driving lights
I am in the process of installing some driving lights on the Titan. But I am having trouble finding a good spot to go through the firewall at . Any suggestions?
I have the lights mounted in the bumper but need to get the wiring done.
2005 2wd SE...Westin Oval tube steps, Rhino Lining, K&N FIPK II
warrenm is offline   Reply With Quote
Old 01-03-2007, 09:49 AM   #2 (permalink)
baseballfanz's Avatar
Re: Firewall access for driving lights
I ran mine through the rubber grommet that they use for the hood release cable (under driver's side).
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 01-03-2007, 09:54 AM   #3 (permalink)
I found that one too but it is a pain to get to...might have to do that.
Did you cut a hole in the grommet or just push/pull the wires through?
Old 01-03-2007, 10:17 AM   #4 (permalink)
Sammy Sandbag's Avatar
You can easily push up to 8ga wire through the grommet, that is how I had my original amp power wire setup.
-Counsel Yourself
Old 01-03-2007, 10:26 AM   #5 (permalink)
I will try it out this weekend...THANKS!
Old 01-03-2007, 10:29 AM   #6 (permalink)
Keep the power wire under the hood by using a relay to turn on the lights. The only thing that need to go through the firewall is the trigger lead for the relay, which can be small gauge as it carries minimal current.
Old 01-03-2007, 10:45 AM   #7 (permalink)
I'm about to do a similiar thing for auxillary reverse lights; will have an in-cabin switch to allow me to run the lights whenever I choose. Where is the best location to tap into an in-cabin +12V hot wire to feed the switch which will trigger the relay?
Thanks...
BHMTitan is offline   Reply With Quote
Old 01-03-2007, 10:53 AM   #8 (permalink)
You can use a fuse tap from Rat Shack or a Little Fuse Mini Blade Add A Circuit to tap the passenger side lighter socket circuit in the fuse box on the passenger side dash. The passenger side lighter socket goes on & off with the ignition so no danger of running the battery down.
Old 01-03-2007, 11:37 AM   #9 (permalink)
Where are you guy's buying your driving (Fog) lights? My SE dosen't have them and the black inserts look pathetic.
Thanks
Redmille is offline   Reply With Quote
Old 01-03-2007, 12:16 PM   #10 (permalink)
Thanks
Best to get the OEM kit, it will come with a new headlight stalk with built in fog lights switch. Your SE is pre-wired for factory fog lights, about 15 to 20 min. install plug and play. http://www.courtesyparts.com/titan/exterior.html
Nissan ODB2 Codes
Old 01-03-2007, 01:21 PM   #11 (permalink)
I wish I would have gone that route with the OEM but got the Optronics 4.5 round driving lights.
Old 01-03-2007, 01:31 PM   #12 (permalink)
I think I will try the fuse tap method...forgot about that one. One could almost eliminate the lighter socket on the passenger side all together...think that is what I will do.
Thanks for all the helpful ideas
Old 01-03-2007, 01:58 PM   #13 (permalink)
Thanks for the Link Basballfanz! Thats the route I'll go!
Old 01-04-2007, 12:45 PM   #14 (permalink)
Good idea, but that fuse is 15A. I've only been able to find 10A max Add-A-Circuit taps.
Old 01-04-2007, 01:11 PM   #15 (permalink)
The 10A rating refers to the circuit that you are adding (the relay trigger circuit). You aren't going to be drawing much juice on a relay trigger lead. The OEM 15A fuse will still protect the lighter socket circuit. Whatever fuse you have in the Add-A-Circuit for your new circuit will protect your wire to the switch for the relay trigger lead. 1 amp would suffice.
http://www.bcae1.com/relays.htm
Driving Lights Toxman Titan Parts & Accessories 1 04-08-2006 01:52 PM
Need some help with Driving Lights TitanOwnr Titan Parts & Accessories 2 02-26-2006 09:01 PM
fog/driving lights Tbot Titan Parts & Accessories 6 01-01-2005 05:14 PM
fog/driving lights Tbot Titan Performance Modifications 3 12-31-2004 11:30 PM
Driving Lights Wiring... CharlienoX Titan Parts & Accessories 2 12-10-2004 09:21 AM
