Old 01-04-2007, 10:35 AM   #1 (permalink)
Yellomantis's Avatar
easiest way to swap mirror caps?
Swapping mirror caps tomorrow along with door handles. Anyone know how to do this? Can't I just use a flat screwdriver and pry the mirror cap off? What is involved with changing the door handles? I have the non big tow mirrors.
www.myspace.com/yellomantis
Old 01-04-2007, 10:43 AM   #2 (permalink)
baseballfanz's Avatar
Re: easiest way to swap mirror caps?
With a long flat blade screw driver, you have to get at the tabs from inside the mirrors. Move the mirror glass itself to one side and using a flash light look for about 4 or 5 locking tabs that need to be push out.
Picture is off the BT mirrors but the non BT procedure is the same.
Handle swap by Qwikwhip
http://titan*spot.com/phpbb2/viewtopic.php?t=225
Remove * between titan and spot.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 01-04-2007, 10:56 AM   #3 (permalink)
CVTITAN's Avatar
Hey Mantis I swapped mirror covers with Tony at one of the SoCal meets. It was really easy. Now I need to change to the chrome door handles. Thanks baseballfanz for the link to the how to. Ill try it when I get home today..
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 01-04-2007, 10:59 AM   #4 (permalink)
Thanks BBF!!!! That write up will help alot! I was thinking I would have to pull the inner door panels to get at everything! You saved me alot of work and headaches!
Old 01-04-2007, 11:05 AM   #5 (permalink)
TitanicDJ's Avatar
Send a message via MSN to TitanicDJ
Hey Yellomantis
I swaped mine out too. Just be careful with the inside bottom plastic clip. I broke off one of mine but still worked ok. Here's another thread that help me with my swap out.
I'm still looking to swapping my chrome door handles with an XE black.
Good Luck to you!
Click here for: Mirror Swap Out
DJ
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
TitanicDJ is offline   Reply With Quote
Old 01-07-2007, 08:12 PM   #6 (permalink)
Banned
mario's Avatar
Send a message via AIM to mario
why swap door handles all u gotta do is remove the chrome cover and donate or sell them at the meet
mario is offline   Reply With Quote
Old 01-07-2007, 08:14 PM   #7 (permalink)
dude, we swapped on friday!
Old 01-08-2007, 11:18 AM   #8 (permalink)
kartman's Avatar
Door handles are easy, you will need a 30 pt torx driver as I recall. Open the dooors and there will be a rubber cap on the inside sill. Remove the cap, unbolt. The driver door is a little tricky but still simple. Whole job is 10-15 minutes.
Rebar Wrangler
Old 01-10-2007, 03:50 PM   #9 (permalink)
Banned
mario's Avatar
we did o sh!it my bad i was all into removing the top grille i though all we did was take of ur chrome and put it on mine dint know my black covers came off
Black mirror caps BT. shift149 Titan Parts & Accessories 8 11-29-2006 10:21 PM
WTB Chrome BT Mirror Caps or trade black mirror caps tyoung1 Buy/Sell 3 08-24-2006 05:46 AM
Chrome Big Tow mirror caps - Phx kartman Buy/Sell 9 08-03-2006 01:01 AM
